I have one problem to SNMP binding with OH2.
Question for the /etc/snmp/snmptrapd.conf (and /etc/openhab2/services/snmp.cfg) entries: Is this only necessary for TRAP operations?
Question for the “GET” operation: Parameter is not documented. Can this parameter be interpreted like “update this item every milliseconds” or how is the GET operation scheduled?
My Item seems never to be used. This means I don’t find any log entries - even in debug mode:
String smp_mem_totl “%s” <it_server> (g_net_snmp_0001, g_typ_srvr) { “snmp=”<[127.0.0.1:public:.1.3.6.1.4.1.2021.4.5.0:10000] }
I also tried to use “Number smp_mem_totl “%d” …”
/etc/snmp/snmptrapd.conf:
disableAuthorization yes
forward default udp:127.0.0.1:5950
/etc/openhab2/services/snmp.cfg:
port=5950
community=public
timeout=1500
retries=0
logging:
2017-04-26 10:10:02.818 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query ‘smp_mem_totl’.
2017-04-26 10:10:03.323 [DEBUG] [org.openhab.binding.snmp ] - BundleEvent STARTING - org.openhab.binding.snmp
2017-04-26 10:10:03.329 [DEBUG] [.binding.snmp.internal.SnmpActivator] - SNMP binding has been started.
2017-04-26 10:10:03.334 [DEBUG] [org.openhab.binding.snmp ] - BundleEvent STARTED - org.openhab.binding.snmp
2017-04-26 10:10:03.342 [DEBUG] [org.openhab.binding.snmp ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.snmp.SnmpBindingProvider}={component.name=org.openhab.binding.snmp.genericbindingprovider, component.id=166, service.id=301, service.bundleid=208, service.scope=bundle} - org.openhab.binding.snmp
2017-04-26 10:10:03.402 [DEBUG] [org.openhab.binding.snmp ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.snmp, component.name=org.openhab.binding.snmp, component.id=165, service.id=303, service.bundleid=208, service.scope=bundle} - org.openhab.binding.snmp
2017-04-26 10:10:03.462 [DEBUG] [ab.binding.snmp.internal.SnmpBinding] - SNMP binding activated
2017-04-26 10:10:03.629 [DEBUG] [ab.binding.snmp.internal.SnmpBinding] - SNMP binding is listening on 0.0.0.0/5950
2017-04-26 10:10:03.646 [INFO ] [b.core.service.AbstractActiveService] - SNMP Refresh Service has been started
So - what to check now?
Thanks in advance …
