I’ve upgraded to some Ubiquiti Unifi networking kit and at the same time changed my local IP range from 192.168.1.x to 192.168.10.x
For some reason SNMP in openHAB is no longer working and I can’t figure it out… I have searched high and low for any reference to the old IP addresses and changed them but still no luck…
Thanks Bruce, using the MIB Browser I can still browse the SNMP of my UPS with the exact same IP, Port and Community so I don’t think any of the new network gear is affecting things.
I’m running openHABianPi on a raspberry pi so I can only suspect something in there is remembering the old IP range or something?
SNMP, as far as I remember, is a v1 binding and it may retain its config even if you modified its .cfg file.
You could clear openHABs cache and let it reload its config from files.
Or, you can search the forum for “config:list”. I remeber using this in relation to mqtt v1 binding. Same thing… The binding had its configuration cached and had to use config:list command from console to view and then edit the config.
