Hi all,
i use many gembird energenie socket strips. Unfortunately, the binding no longer works reliably. which multiple socket do you use? Does anyone know one based on z-wave or wifi?
thanks
Hi all,
thanks
I just use a single gembird energenie socket strip (EG-PM2-LAN), but i didn’t notice any problems. What kind of reliability problems do you notice?
hi job, thanks for your reply. i use five EG-PMS2-LAN and one EG-PMS2-WLAN.The binding suddenly stops working. i cannot control the strip anymore. After a restart from openhabian, all works fine. the webserver from the socket works all the time and im not login from another device. i can exclude a network problem. the problem was since my upgrade vom oh 2.1 stable to oh 2.2 stable.
Do you notice any log entries?
Hi job,
no error logs. i see the command logs but the sockets does not respond.
2018-01-25 11:00:04.078 [ome.event.ItemCommandEvent] - Item ‘DG_SZ_Tischlampe’ received command OFF
2018-01-25 11:00:04.106 [vent.ItemStateChangedEvent] - DG_SZ_Tischlampe changed from ON to OFF
are there any other places where i can view error logs except /var/log ?
thanks
