I am using Fine Offset Weather Station Binding with GW1000. I have several temperature sensors which work very stable.
Yesterday I’ve connected two soil moisture sensors and I am observing strange behaviors.
- On the GW1000 Thing page on the Channels tab, the Thing is switching between the Temperature/Humidity sensors and the Moisture sensors every few seconds. I do not see all sensors at once - the list is switching back and forth between two “pages” of sensors.
- The soil moisture readings switch between percentage and decimal reading every 5 minutes. For example if the moisture is
49%
every 5 minutes it changes to0.49
and five minutes later back to49%
and 5 minutes later to0.49
and so on…
Did I mess something in the configuration?
