Platform information:
- Hardware: ARM
- OS: Linux/Debian/OpenHabianPi
- Java Runtime Environment: openjdk version “1.8. 0_121”
- openHAB version: openHAB 2.1.0-1 (Release Build)
Issue of the topic:
I have two Aeotec Multisensor 6 and i use them at the moment like this: 1 sensor is placed in bathroom, 1 is placed in the kitchen. Evertime the temperature changes i would like to send a telegram message. THe rules i created works so far, when there is just one single rules file. For example when i have only kitchen.rules i receive a message every time the temperature changes. But when i create a copy of this file and change it to use the bathroom sensor, i changed all “kitchen” related code, then only one of the rules files seems to work. I can not say which one, because, it seems to be randomly, everytime when i do some changes, another rules file works. I hope i could describe my problem understandable.
Used Items files:
kitchen.items
// Boiler
Number Boiler_1G_Kueche_Verbrauch "momentaner Verbrauch Boiler [%.2f W]" <energy> (1G_Kueche) { channel="zwave:device:Razberry2:node2:sensor_power" }
Switch Boiler_1G_Kueche_Switch "Boiler Küche" <faucet> (1G_Kueche) { channel="zwave:device:Razberry2:node2:switch_binary"}
// Sensor
Number Temperatur_1G_Kueche "Zimmer Temperatur [%.1f °C]" <temperature> (1G_Kueche) { channel="zwave:device:Razberry2:node4:sensor_temperature" }
Number Luftfeuchtigkeit_1G_Kueche "Luftfeuchtigkeit [%.2f %%]" <humidity> (1G_Kueche) { channel="zwave:device:Razberry2:node4:sensor_relhumidity" }
Number Helligkeit_1G_Kueche "Helligkeit [%.2f Lux]" <colorlight> (1G_Kueche) { channel="zwave:device:Razberry2:node4:sensor_luminance" }
Switch Bewegung_1G_Kueche "Bewegung erkannt" (1G_Kueche) { channel="zwave:device:Razberry2:node4:alarm_motion" }
// Kodi
String Kodi_1G_Kueche_Notification "Notification" (1G_Kueche) { channel="kodi:kodi:kitchen:shownotification" }
bad.items
Number Temperatur_1G_Bad "Zimmer Temperatur [%.1f °C]" <temperature> (1G_Bad) { channel="zwave:device:Razberry2:node11:sensor_temperature" }
Number Luftfeuchtigkeit_1G_Bad "Luftfeuchtigkeit [%.2f %%]" <humidity> (1G_Bad) { channel="zwave:device:Razberry2:node11:sensor_relhumidity" }
Number Helligkeit_1G_Bad "Helligkeit [%.2f Lux]" <colorlight> (1G_Bad) { channel="zwave:device:Razberry2:node11:sensor_luminance" }
Number Boiler_1G_Bad_Verbrauch "momentaner Verbrauch Boiler [%.2f W]" <energy> (1G_Bad) { channel="zwave:device:Razberry2:node7:sensor_power" }
Used rules files
kitchen.rules
//### Rule warmup
rule "kitchen.rules loaded Event"
System started
logInfo("Warmup","kitchen.rules warmup completed")
// Abschalten des Küchen Boilers nach erreichen der Temperatur
rule "Turn Off Boiler After Warmup"
Item Boiler_1G_Kueche_Switch received command ON
Thread::sleep(10000)
while (Boiler_1G_Kueche_Verbrauch.state > 100.0) {
logInfo("Boiler Küche: ","Aufheizphase aktiv!")
Boiler_1G_Kueche_Switch.send(OFF);
logInfo("Boiler Küche: ","Automatische Abschaltung bei " + Boiler_1G_Kueche_Verbrauch.state + " W")
// Sende Zimmer Temperatur Status per Telegram
rule "Send Temperatur to Telegram"
Item Temperatur_1G_Kueche changed
logInfo("Temperatur Küche: ","Sende Telegram Message")
if (Temperatur_1G_Kueche.state as Number > 20.0){
sendTelegram("FlOpenHABot", "\uD83D\uDD25 Die Temperatur in der Küche beträgt jetzt %s Grad Celsius.", Temperatur_1G_Kueche.state.toString)
else {
sendTelegram("FlOpenHABot", "\u2744 Die Temperatur in der Küche beträgt jetzt %s Grad Celsius.", Temperatur_1G_Kueche.state.toString)
bad.rules
//### Rule warmup
rule "bad.rules loaded Event"
System started
logInfo("Warmup","bad.rules warmup completed")
// Abschalten des Bad Boilers nach erreichen der Temperatur
Item Boiler_1G_Bad_Switch received command ON
while (Boiler_1G_Bad_Verbrauch.state > 100.0) {
logInfo("Boiler Bad: ","Aufheizphase aktiv!")
Boiler_1G_Bad_Switch.send(OFF);
logInfo("Boiler Bad: ","Automatische Abschaltung bei " + Boiler_1G_Bad_Verbrauch.state + " W")
sendTelegram("FlOpenHABot", "Der Boiler im Badezimmer hat seine Zieltemperatur erreicht!")
Item Temperatur_1G_Bad changed
logInfo("Temperatur Bad: ","Sende Telegram Message")
if (Temperatur_1G_Bad.state as Number > 15.0){
sendTelegram("FlOpenHABot", "\uD83D\uDD25 Die Temperatur im Bad beträgt jetzt %s Grad Celsius. ", Temperatur_1G_Bad.state.toString)
else {
sendTelegram("FlOpenHABot", "\u2744 Die Temperatur im Bad beträgt jetzt %s Grad Celsius. ", Temperatur_1G_Bad.state.toString)
