[SOLVED] 2 Time periods in Rule
Hi all,
I currently have a rule running for turning my lights on when LUX is bellow
rule "Turn Sidelight On_LUX"
    Item WeatherUV2 changed
    if(now.getHourOfDay() >5 && now.getHourOfDay() <22){
    if (GroundLights.state == OFF && WeatherUV2.state < 100){
    GroundLights.sendCommand(ON)
    sendBroadcastNotification("Side Lights ON")
I want to split the time in to 2 periods, something like;
    if(now.getHourOfDay() >5 && now.getHourOfDay() <7){
    if(now.getHourOfDay() >16 && now.getHourOfDay() <22){
However i cant work out the correct command to use either one time period or the other.
Any help would be appreciated.
This tests first whether it is between 5-7 and then tests whether it is between 16-20, which will never be true as the first if statement requires it to be between 5-7
Try this
if(now.getHourOfDay() >5 && now.getHourOfDay() <7) OR (now.getHourOfDay() >16 && now.getHourOfDay() <22) {
Thanks @lipp_markus
