It should normally only log that if it’s already scanning for lights and you press the discovery button for the LIFX binding again. The discovery thread could be deadlocked so it keeps logging that.
What might help explaining this is a thread dump.
Can you attach the output of the following command on the Karaf Console?:
openhab> threads --locks --monitors
"CM Configuration Updater" Id=28 in WAITING on lock=java.util.LinkedList@5abd0c12
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:502)
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:79)
at java.lang.Thread.run(Thread.java:748)
"CM Event Dispatcher" Id=29 in WAITING on lock=java.util.LinkedList@10398784
"fileinstall-/usr/share/openhab2/addons" Id=39 in TIMED_WAITING on lock=org.apache.felix.fileinstall.internal.DirectoryWatcher@49f067c6
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:320)
"pool-1-thread-1" Id=45 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@d38b13e
at sun.misc.Unsafe.park(Native Method)
at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078)
at java.util.concurrent.LinkedBlockingDeque.pollFirst(LinkedBlockingDeque.java:522)
at java.util.concurrent.LinkedBlockingDeque.poll(LinkedBlockingDeque.java:684)
at sun.nio.fs.AbstractWatchService.poll(AbstractWatchService.java:108)
at org.apache.karaf.jaas.modules.properties.AutoEncryptionSupport.run(AutoEncryptionSupport.java:77)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Locked synchronizers: count = 1
- java.util.concurrent.ThreadPoolExecutor$Worker@6090c748
"openHAB-job-scheduler_QuartzSchedulerThread" Id=94 in TIMED_WAITING on lock=java.lang.Object@3b87582
at org.quartz.core.QuartzSchedulerThread.run(QuartzSchedulerThread.java:311)
"main" Id=1 in WAITING on lock=java.util.concurrent.atomic.AtomicReference@75774e1d
at org.eclipse.osgi.container.SystemModule.waitForStop(SystemModule.java:168)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle.waitForStop(EquinoxBundle.java:250)
at org.eclipse.osgi.launch.Equinox.waitForStop(Equinox.java:181)
at org.apache.karaf.main.Main.awaitShutdown(Main.java:641)
at org.apache.karaf.main.Main.main(Main.java:188)
"Framework Event Dispatcher: org.eclipse.osgi.internal.framework.EquinoxEventPublisher@3e44f2a5" Id=13 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@7b3c49e9
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:400)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:336)
"Start Level: Equinox Container: 8b59bb24-4e17-465d-b172-4867f6a67852" Id=14 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@3b446761
"Karaf Lock Monitor Thread" Id=15 in TIMED_WAITING
at java.lang.Thread.sleep(Native Method)
at org.apache.karaf.main.Main.doMonitor(Main.java:404)
at org.apache.karaf.main.Main.access$100(Main.java:74)
at org.apache.karaf.main.Main$3.run(Main.java:377)
"Karaf Shutdown Socket Thread" Id=16 in RUNNABLE (running in native)
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.AbstractPlainSocketImpl.accept(AbstractPlainSocketImpl.java:409)
at java.net.ServerSocket.implAccept(ServerSocket.java:545)
at java.net.ServerSocket.accept(ServerSocket.java:513)
at org.apache.karaf.main.ShutdownSocketThread.run(ShutdownSocketThread.java:65)
"fileinstall-/var/lib/openhab2/etc" Id=31 in TIMED_WAITING on lock=org.apache.felix.fileinstall.internal.DirectoryWatcher@b0cfa36
"Bundle File Closer" Id=41 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@4d7aca91
"SCR Component Actor" Id=42 in WAITING on lock=java.util.LinkedList@f90b3fb
at org.apache.felix.scr.impl.ComponentActorThread.run(ComponentActorThread.java:83)
"pool-3-thread-1" Id=49 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@45d82ac2
- java.util.concurrent.ThreadPoolExecutor$Worker@7b4459ce
"qtp2083006768-71-acceptor-0@71999366-0.0.0.0:8443@76fe7e83{SSL,[ssl, http/1.1]}{0.0.0.0:8443}" Id=71 in RUNNABLE (running in native)
at sun.nio.ch.ServerSocketChannelImpl.accept0(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:422)
at sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:250)
- locked java.lang.Object@2b4f9d42
at org.eclipse.jetty.server.ServerConnector.accept(ServerConnector.java:369)
at org.eclipse.jetty.server.AbstractConnector$Acceptor.run(AbstractConnector.java:639)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680)
Locked monitors: count = 1
- java.lang.Object@2b4f9d42 locked at
2 sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:250)
"qtp2083006768-74-acceptor-0@179dcaf7-default@21b52029{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}" Id=74 in RUNNABLE (running in native)
- locked java.lang.Object@623a20ef
- java.lang.Object@623a20ef locked at
"Dir Watcher" Id=78 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@41b70e41
at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039)
at java.util.concurrent.LinkedBlockingDeque.takeFirst(LinkedBlockingDeque.java:492)
at java.util.concurrent.LinkedBlockingDeque.take(LinkedBlockingDeque.java:680)
at sun.nio.fs.AbstractWatchService.take(AbstractWatchService.java:118)
at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:210)
"ESH-OSGiEventManager" Id=83 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@30c35288
at java.util.concurrent.LinkedBlockingQueue.poll(LinkedBlockingQueue.java:467)
at org.eclipse.smarthome.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:61)
at org.eclipse.smarthome.core.internal.events.ThreadedEventHandler$$Lambda$177/1408662846.run(Unknown Source)
"openHAB-job-scheduler_Worker-1" Id=92 in TIMED_WAITING on lock=java.lang.Object@23255b99
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:568)
"openHAB-job-scheduler_Worker-2" Id=93 in TIMED_WAITING on lock=java.lang.Object@18b52490
"EMF Reference Cleaner" Id=96 in WAITING on lock=java.lang.ref.ReferenceQueue$Lock@1f71908d
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:144)
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:165)
at org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread.run(CommonUtil.java:70)
"com.google.inject.internal.util.$Finalizer" Id=126 in WAITING on lock=java.lang.ref.ReferenceQueue$Lock@1587a9ee
at com.google.inject.internal.util.$Finalizer.run(Finalizer.java:114)
"Karaf ssh console user openhab" Id=136 in WAITING on lock=org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl@1f9d7428
at org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl.start(CommandSessionImpl.java:798)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:300)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:169)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:149)
at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:179)
at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.doExecute(ConsoleSessionImpl.java:462)
at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.run(ConsoleSessionImpl.java:402)
"job controller 1" Id=138 in WAITING on lock=java.util.concurrent.FutureTask@6d7f3c4c
at java.util.concurrent.FutureTask.awaitDone(FutureTask.java:429)
at java.util.concurrent.FutureTask.get(FutureTask.java:191)
at java.util.concurrent.AbstractExecutorService.invokeAll(AbstractExecutorService.java:244)
at org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl.run(CommandSessionImpl.java:823)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
- java.util.concurrent.ThreadPoolExecutor$Worker@7280e99f
"pipe-log:tail" Id=140 in WAITING on lock=org.apache.karaf.log.command.LogTail@3a205aac
at org.apache.karaf.log.command.LogTail.execute(LogTail.java:57)
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84)
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68)
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86)
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599)
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415)
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416)
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229)
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59)
- java.util.concurrent.ThreadPoolExecutor$Worker@477a05a1
"SocketListener(JmDNS-/192.168.1.114)" Id=148 in RUNNABLE (running in native)
at java.net.PlainDatagramSocketImpl.peekData(Native Method)
- locked java.net.PlainDatagramSocketImpl@13404531
at java.net.DatagramSocket.receive(DatagramSocket.java:743)
- locked java.net.DatagramPacket@2cd61544
- locked java.net.MulticastSocket@638691dd
at javax.jmdns.impl.SocketListener.run(SocketListener.java:41)
Locked monitors: count = 3
- java.net.PlainDatagramSocketImpl@13404531 locked at
0 java.net.PlainDatagramSocketImpl.peekData(Native Method)
- java.net.DatagramPacket@2cd61544 locked at
1 java.net.DatagramSocket.receive(DatagramSocket.java:743)
- java.net.MulticastSocket@638691dd locked at
"lsp-1" Id=157 in RUNNABLE (running in native)
at org.eclipse.smarthome.model.lsp.internal.ModelServer.listen(ModelServer.java:99)
at org.eclipse.smarthome.model.lsp.internal.ModelServer.lambda$0(ModelServer.java:78)
at org.eclipse.smarthome.model.lsp.internal.ModelServer$$Lambda$478/1641745382.run(Unknown Source)
- java.util.concurrent.ThreadPoolExecutor$Worker@f3a6120
"Thread-63" Id=186 in TIMED_WAITING
at org.openhab.binding.zwave.handler.ZWaveSerialHandler$ZWaveReceiveThread.serialEvent(ZWaveSerialHandler.java:170)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:780)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1611)
"ZWaveReceiveInputThread" Id=187 in RUNNABLE (running in native)
at gnu.io.RXTXPort.readByte(Native Method)
at gnu.io.RXTXPort$SerialInputStream.read(RXTXPort.java:1286)
- locked gnu.io.RXTXPort$SerialInputStream@49b08ad4
at org.openhab.binding.zwave.handler.ZWaveSerialHandler$ZWaveReceiveThread.run(ZWaveSerialHandler.java:215)
- gnu.io.RXTXPort$SerialInputStream@49b08ad4 locked at
1 gnu.io.RXTXPort$SerialInputStream.read(RXTXPort.java:1286)
"ZWaveReceiveProcessorThread" Id=189 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1efae286
at java.util.concurrent.ArrayBlockingQueue.take(ArrayBlockingQueue.java:403)
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$ZWaveReceiveThread.run(ZWaveTransactionManager.java:427)
"Thread-69" Id=199 in RUNNABLE (running in native)
at java.net.PlainDatagramSocketImpl.receive0(Native Method)
- locked java.net.PlainDatagramSocketImpl@37d3c3d3
at java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:143)
at java.net.DatagramSocket.receive(DatagramSocket.java:812)
- locked java.net.DatagramPacket@78a8be3d
- locked java.net.DatagramSocket@43a52c31
at org.openhab.binding.network.internal.dhcp.DHCPPacketListenerServer.run(DHCPPacketListenerServer.java:96)
Locked monitors: count = 4
- java.net.PlainDatagramSocketImpl@37d3c3d3 locked at
0 java.net.PlainDatagramSocketImpl.receive0(Native Method)
1 java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:143)
- java.net.DatagramPacket@78a8be3d locked at
2 java.net.DatagramSocket.receive(DatagramSocket.java:812)
- java.net.DatagramSocket@43a52c31 locked at
"ServletModel-23-207" Id=207 in RUNNABLE (running in native)
at sun.nio.ch.EPollArrayWrapper.epollWait(Native Method)
at sun.nio.ch.EPollArrayWrapper.poll(EPollArrayWrapper.java:269)
at sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:93)
at sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:86)
- locked sun.nio.ch.Util$3@2720a5e3
- locked java.util.Collections$UnmodifiableSet@5a212c76
- locked sun.nio.ch.EPollSelectorImpl@3b8e975b
at sun.nio.ch.SelectorImpl.select(SelectorImpl.java:97)
at sun.nio.ch.SelectorImpl.select(SelectorImpl.java:101)
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.select(ManagedSelector.java:396)
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produceTask(EatWhatYouKill.java:357)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:181)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:132)
at org.eclipse.jetty.io.ManagedSelector$$Lambda$156/904331579.run(Unknown Source)
- sun.nio.ch.Util$3@2720a5e3 locked at
3 sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:86)
- java.util.Collections$UnmodifiableSet@5a212c76 locked at
- sun.nio.ch.EPollSelectorImpl@3b8e975b locked at
"ServletModel-23-208" Id=208 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@57654f2f
at org.eclipse.jetty.util.BlockingArrayQueue.poll(BlockingArrayQueue.java:392)
at org.eclipse.jetty.util.thread.QueuedThreadPool.idleJobPoll(QueuedThreadPool.java:653)
at org.eclipse.jetty.util.thread.QueuedThreadPool.access$800(QueuedThreadPool.java:48)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:717)
"ServletModel-23-209" Id=209 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@57654f2f
"ServletModel-23-210" Id=210 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@57654f2f
"ServletModel-23-211" Id=211 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@57654f2f
"ServletModel-23-212" Id=212 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@57654f2f
"ServletModel-23-213" Id=213 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@57654f2f
"ServletModel-23-214" Id=214 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@275aede5
- locked java.util.Collections$UnmodifiableSet@5af4e110
- locked sun.nio.ch.EPollSelectorImpl@17fec617
- sun.nio.ch.Util$3@275aede5 locked at
- java.util.Collections$UnmodifiableSet@5af4e110 locked at
- sun.nio.ch.EPollSelectorImpl@17fec617 locked at
"upnp-main-1" Id=219 in TIMED_WAITING
at org.jupnp.registry.RegistryMaintainer.run(RegistryMaintainer.java:51)
- java.util.concurrent.ThreadPoolExecutor$Worker@228ff4f4
"upnp-main-2" Id=220 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@24070bda
- locked java.net.DatagramPacket@3249e355
- locked java.net.MulticastSocket@1e1a7bb2
at org.jupnp.transport.impl.MulticastReceiverImpl.run(MulticastReceiverImpl.java:114)
- java.util.concurrent.ThreadPoolExecutor$Worker@2714fe1a
- java.net.PlainDatagramSocketImpl@24070bda locked at
- java.net.DatagramPacket@3249e355 locked at
- java.net.MulticastSocket@1e1a7bb2 locked at
"upnp-main-4" Id=222 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@59b9ec3b
- locked java.net.DatagramPacket@20b189df
- locked java.net.MulticastSocket@35221056
at org.jupnp.transport.impl.DatagramIOImpl.run(DatagramIOImpl.java:111)
- java.util.concurrent.ThreadPoolExecutor$Worker@3a88a32a
- java.net.PlainDatagramSocketImpl@59b9ec3b locked at
- java.net.DatagramPacket@20b189df locked at
- java.net.MulticastSocket@35221056 locked at
"Thread-85" Id=231 in RUNNABLE (running in native)
"AshFrameHandler" Id=255 in TIMED_WAITING on lock=org.openhab.binding.zigbee.handler.ZigBeeSerialPort@60debb04
at org.openhab.binding.zigbee.handler.ZigBeeSerialPort.read(ZigBeeSerialPort.java:243)
at org.openhab.binding.zigbee.handler.ZigBeeSerialPort.read(ZigBeeSerialPort.java:219)
at com.zsmartsystems.zigbee.dongle.ember.internal.ash.AshFrameHandler.getPacket(AshFrameHandler.java:276)
at com.zsmartsystems.zigbee.dongle.ember.internal.ash.AshFrameHandler.access$200(AshFrameHandler.java:50)
at com.zsmartsystems.zigbee.dongle.ember.internal.ash.AshFrameHandler$1.run(AshFrameHandler.java:158)
"Expire Refresh Service" Id=264 in TIMED_WAITING
at org.openhab.core.service.AbstractActiveService$RefreshThread.pause(AbstractActiveService.java:186)
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:170)
"OkHttp ConnectionPool" Id=283 in TIMED_WAITING on lock=com.squareup.okhttp.ConnectionPool@35d0a0de
at java.lang.Object.wait(Object.java:460)
at com.squareup.okhttp.ConnectionPool.performCleanup(ConnectionPool.java:305)
at com.squareup.okhttp.ConnectionPool.runCleanupUntilPoolIsEmpty(ConnectionPool.java:242)
at com.squareup.okhttp.ConnectionPool.access$000(ConnectionPool.java:54)
at com.squareup.okhttp.ConnectionPool$1.run(ConnectionPool.java:97)
- java.util.concurrent.ThreadPoolExecutor$Worker@dfff25f
"ESH-persist-Monitor-1" Id=284 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2608876e
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2163)
at org.eclipse.smarthome.core.scheduler.ExpressionThreadPoolManager$ExpressionThreadPoolExecutor$1.run(ExpressionThreadPoolManager.java:270)
"HttpClient@5011fd97-289" Id=289 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@684f40b7
- locked java.util.Collections$UnmodifiableSet@4e4ba019
- locked sun.nio.ch.EPollSelectorImpl@1a430cca
- sun.nio.ch.Util$3@684f40b7 locked at
- java.util.Collections$UnmodifiableSet@4e4ba019 locked at
- sun.nio.ch.EPollSelectorImpl@1a430cca locked at
"HttpClient@5011fd97-290" Id=290 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7d633f96
"HttpClient@5011fd97-291" Id=291 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7d633f96
"HttpClient@5011fd97-292" Id=292 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7d633f96
"HttpClient@5011fd97-293" Id=293 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@4edd0fe8
- locked java.util.Collections$UnmodifiableSet@6b57f173
- locked sun.nio.ch.EPollSelectorImpl@c344128
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
- sun.nio.ch.Util$3@4edd0fe8 locked at
- java.util.Collections$UnmodifiableSet@6b57f173 locked at
- sun.nio.ch.EPollSelectorImpl@c344128 locked at
"HttpClient@5011fd97-294" Id=294 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7d633f96
"HttpClient@5011fd97-295" Id=295 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7d633f96
"HttpClient@5011fd97-296" Id=296 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7d633f96
"nioEventLoopGroup-2-1" Id=297 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@661aa2f0
- locked java.util.Collections$UnmodifiableSet@596f9818
- locked sun.nio.ch.EPollSelectorImpl@44c7908
at io.netty.channel.nio.SelectedSelectionKeySetSelector.select(SelectedSelectionKeySetSelector.java:62)
at io.netty.channel.nio.NioEventLoop.select(NioEventLoop.java:753)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:409)
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:886)
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
- io.netty.channel.nio.SelectedSelectionKeySet@661aa2f0 locked at
- java.util.Collections$UnmodifiableSet@596f9818 locked at
- sun.nio.ch.EPollSelectorImpl@44c7908 locked at
"nioEventLoopGroup-3-1" Id=300 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@4f0ca550
- locked java.util.Collections$UnmodifiableSet@7968c457
- locked sun.nio.ch.EPollSelectorImpl@271f5c29
- io.netty.channel.nio.SelectedSelectionKeySet@4f0ca550 locked at
- java.util.Collections$UnmodifiableSet@7968c457 locked at
- sun.nio.ch.EPollSelectorImpl@271f5c29 locked at
"MQTT Call: embedded-mqtt-broker" Id=301 in WAITING on lock=java.lang.Object@68b07a5f
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:173)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
- java.util.concurrent.ThreadPoolExecutor$Worker@11d8a7bb
"nioEventLoopGroup-3-2" Id=302 in RUNNABLE
- locked io.netty.channel.nio.SelectedSelectionKeySet@d5549d0
- locked java.util.Collections$UnmodifiableSet@3080ca4c
- locked sun.nio.ch.EPollSelectorImpl@289ed6ed
- io.netty.channel.nio.SelectedSelectionKeySet@d5549d0 locked at
- java.util.Collections$UnmodifiableSet@3080ca4c locked at
- sun.nio.ch.EPollSelectorImpl@289ed6ed locked at
"MQTT Rec: embedded-mqtt-broker" Id=303 in RUNNABLE (running in native)
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:171)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at java.net.SocketInputStream.read(SocketInputStream.java:224)
at java.io.DataInputStream.readByte(DataInputStream.java:265)
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:92)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:133)
- java.util.concurrent.ThreadPoolExecutor$Worker@722f32ea
"MQTT Snd: embedded-mqtt-broker" Id=304 in WAITING on lock=java.lang.Object@4fd1e7f6
at org.eclipse.paho.client.mqttv3.internal.ClientState.get(ClientState.java:777)
at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(CommsSender.java:125)
- java.util.concurrent.ThreadPoolExecutor$Worker@4a5ae6f4
"nioEventLoopGroup-3-3" Id=469 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@621cb4d8
- locked java.util.Collections$UnmodifiableSet@1e6cdeaf
- locked sun.nio.ch.EPollSelectorImpl@13e61215
- io.netty.channel.nio.SelectedSelectionKeySet@621cb4d8 locked at
- java.util.Collections$UnmodifiableSet@1e6cdeaf locked at
- sun.nio.ch.EPollSelectorImpl@13e61215 locked at
"nioEventLoopGroup-3-4" Id=40195 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@3b1fd159
- locked java.util.Collections$UnmodifiableSet@464b7d0f
- locked sun.nio.ch.EPollSelectorImpl@25f4a7c
- io.netty.channel.nio.SelectedSelectionKeySet@3b1fd159 locked at
- java.util.Collections$UnmodifiableSet@464b7d0f locked at
- sun.nio.ch.EPollSelectorImpl@25f4a7c locked at
"nioEventLoopGroup-3-5" Id=80069 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@3878ba37
- locked java.util.Collections$UnmodifiableSet@126ad745
- locked sun.nio.ch.EPollSelectorImpl@6245b573
- io.netty.channel.nio.SelectedSelectionKeySet@3878ba37 locked at
- java.util.Collections$UnmodifiableSet@126ad745 locked at
- sun.nio.ch.EPollSelectorImpl@6245b573 locked at
"Karaf ssh console user openhab" Id=82929 in WAITING on lock=org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl@201f3399
"job controller 1" Id=82930 in WAITING on lock=java.util.concurrent.FutureTask@5c258f54
- java.util.concurrent.ThreadPoolExecutor$Worker@2536e9c3
"pipe-log:tail" Id=82931 in WAITING on lock=org.apache.karaf.log.command.LogTail@47edaaaf
- java.util.concurrent.ThreadPoolExecutor$Worker@66c965b8
"org.apache.karaf.shell.ssh.SshTerminal@15e790f7 input pump thread" Id=85644 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@702d0a5f
at org.apache.sshd.common.channel.ChannelPipedInputStream.read(ChannelPipedInputStream.java:139)
at java.io.InputStream.read(InputStream.java:101)
at org.jline.terminal.impl.ExternalTerminal.pump(ExternalTerminal.java:122)
at org.jline.terminal.impl.ExternalTerminal$$Lambda$272/141084230.run(Unknown Source)
"Karaf ssh console user openhab" Id=85645 in WAITING on lock=org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl@25cb31b8
"pipe-threads --locks --monitors" Id=85646 in RUNNABLE
at sun.management.ThreadImpl.dumpThreads0(Native Method)
at sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:454)
at org.apache.karaf.shell.commands.impl.ThreadsAction.execute(ThreadsAction.java:78)
- java.util.concurrent.ThreadPoolExecutor$Worker@2f46c3a4
"job controller 1" Id=85647 in WAITING on lock=java.util.concurrent.FutureTask@1a202e68
- java.util.concurrent.ThreadPoolExecutor$Worker@143c6dd9
"nioEventLoopGroup-3-6" Id=115754 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@2e9238cc
- locked java.util.Collections$UnmodifiableSet@7d551cd2
- locked sun.nio.ch.EPollSelectorImpl@42beb92c
- io.netty.channel.nio.SelectedSelectionKeySet@2e9238cc locked at
- java.util.Collections$UnmodifiableSet@7d551cd2 locked at
- sun.nio.ch.EPollSelectorImpl@42beb92c locked at
"OkHttp ConnectionPool" Id=118851 in TIMED_WAITING on lock=okhttp3.ConnectionPool@1c0889ca
at okhttp3.ConnectionPool$1.run(ConnectionPool.java:66)
- java.util.concurrent.ThreadPoolExecutor$Worker@54528bff
"OkHttp https://myopenhab.org/..." Id=119236 in RUNNABLE (running in native)
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465)
at sun.security.ssl.InputRecord.read(InputRecord.java:503)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983)
- locked java.lang.Object@cfbfdf9
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940)
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105)
- locked sun.security.ssl.AppInputStream@36a13eba
at okio.Okio$2.read(Okio.java:138)
at okio.AsyncTimeout$2.read(AsyncTimeout.java:238)
at okio.RealBufferedSource.request(RealBufferedSource.java:66)
at okio.RealBufferedSource.require(RealBufferedSource.java:59)
at okio.RealBufferedSource.readByte(RealBufferedSource.java:72)
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:115)
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:104)
at okhttp3.internal.ws.RealWebSocket.readMessage(RealWebSocket.java:97)
at okhttp3.ws.WebSocketCall.createWebSocket(WebSocketCall.java:152)
at okhttp3.ws.WebSocketCall.access$000(WebSocketCall.java:41)
at okhttp3.ws.WebSocketCall$1.onResponse(WebSocketCall.java:97)
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:126)
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32)
- java.util.concurrent.ThreadPoolExecutor$Worker@53d6baf
Locked monitors: count = 2
- java.lang.Object@cfbfdf9 locked at
6 sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983)
- sun.security.ssl.AppInputStream@36a13eba locked at
8 sun.security.ssl.AppInputStream.read(AppInputStream.java:105)
"HttpClient@1f0540c6-119240" Id=119240 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@52e56bf8
- locked java.util.Collections$UnmodifiableSet@477d2fe
- locked sun.nio.ch.EPollSelectorImpl@12171286
- sun.nio.ch.Util$3@52e56bf8 locked at
- java.util.Collections$UnmodifiableSet@477d2fe locked at
- sun.nio.ch.EPollSelectorImpl@12171286 locked at
"HttpClient@1f0540c6-119241" Id=119241 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@3e3d1f2d
- locked java.util.Collections$UnmodifiableSet@174036c0
- locked sun.nio.ch.EPollSelectorImpl@1e5f32e3
- sun.nio.ch.Util$3@3e3d1f2d locked at
- java.util.Collections$UnmodifiableSet@174036c0 locked at
- sun.nio.ch.EPollSelectorImpl@1e5f32e3 locked at
"HttpClient@1f0540c6-119242" Id=119242 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@66954c7c
"HttpClient@1f0540c6-119243" Id=119243 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@66954c7c
"HttpClient@1f0540c6-119244" Id=119244 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@66954c7c
"HttpClient@1f0540c6-119245" Id=119245 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@66954c7c
"HttpClient@1f0540c6-119246" Id=119246 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@66954c7c
"HttpClient@1f0540c6-119247" Id=119247 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@66954c7c
"nioEventLoopGroup-3-7" Id=151924 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@12095f3c
- locked java.util.Collections$UnmodifiableSet@1a066a40
- locked sun.nio.ch.EPollSelectorImpl@2f54d84b
- io.netty.channel.nio.SelectedSelectionKeySet@12095f3c locked at
- java.util.Collections$UnmodifiableSet@1a066a40 locked at
- sun.nio.ch.EPollSelectorImpl@2f54d84b locked at
"jupnp-jetty-client-169403" Id=169403 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@4f1c5d1f
"nioEventLoopGroup-3-8" Id=188021 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@32c7580d
- locked java.util.Collections$UnmodifiableSet@2c933e9d
- locked sun.nio.ch.EPollSelectorImpl@5cc2b944
- io.netty.channel.nio.SelectedSelectionKeySet@32c7580d locked at
- java.util.Collections$UnmodifiableSet@2c933e9d locked at
- sun.nio.ch.EPollSelectorImpl@5cc2b944 locked at
"jupnp-jetty-client-190264" Id=190264 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@5319ba62
- locked java.util.Collections$UnmodifiableSet@3be73f8
- locked sun.nio.ch.EPollSelectorImpl@67c53818
- sun.nio.ch.Util$3@5319ba62 locked at
- java.util.Collections$UnmodifiableSet@3be73f8 locked at
- sun.nio.ch.EPollSelectorImpl@67c53818 locked at
"jupnp-jetty-client-211247" Id=211247 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2af9dcd3
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.reservedWait(ReservedThreadExecutor.java:292)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:357)
"jupnp-jetty-client-211606" Id=211606 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7e95dc4d
"qtp2083006768-222544" Id=222544 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@50a9ead9
"qtp2083006768-223323" Id=223323 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@6fc76ffb
- locked java.util.Collections$UnmodifiableSet@718c4d7f
- locked sun.nio.ch.EPollSelectorImpl@2ff8a0cd
- sun.nio.ch.Util$3@6fc76ffb locked at
- java.util.Collections$UnmodifiableSet@718c4d7f locked at
- sun.nio.ch.EPollSelectorImpl@2ff8a0cd locked at
"qtp2083006768-223896" Id=223896 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@14015a96
- locked java.util.Collections$UnmodifiableSet@5ae0994a
- locked sun.nio.ch.EPollSelectorImpl@7d95953a
- sun.nio.ch.Util$3@14015a96 locked at
- java.util.Collections$UnmodifiableSet@5ae0994a locked at
- sun.nio.ch.EPollSelectorImpl@7d95953a locked at
"jupnp-jetty-client-224453" Id=224453 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@195aeea2
- locked java.util.Collections$UnmodifiableSet@4f3d1df9
- locked sun.nio.ch.EPollSelectorImpl@62ee15d6
- sun.nio.ch.Util$3@195aeea2 locked at
- java.util.Collections$UnmodifiableSet@4f3d1df9 locked at
- sun.nio.ch.EPollSelectorImpl@62ee15d6 locked at
"qtp2083006768-225434" Id=225434 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@347c49b1
- locked java.util.Collections$UnmodifiableSet@17c74737
- locked sun.nio.ch.EPollSelectorImpl@2d0b6247
- sun.nio.ch.Util$3@347c49b1 locked at
- java.util.Collections$UnmodifiableSet@17c74737 locked at
- sun.nio.ch.EPollSelectorImpl@2d0b6247 locked at
"qtp2083006768-227068" Id=227068 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@50a9ead9
"qtp2083006768-227121" Id=227121 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$3@4c4d2213
- locked java.util.Collections$UnmodifiableSet@61584809
- locked sun.nio.ch.EPollSelectorImpl@7eb899d9
- sun.nio.ch.Util$3@4c4d2213 locked at
- java.util.Collections$UnmodifiableSet@61584809 locked at
- sun.nio.ch.EPollSelectorImpl@7eb899d9 locked at
"qtp2083006768-227542" Id=227542 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2759014f
"qtp2083006768-227544" Id=227544 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@50a9ead9
"qtp2083006768-227893" Id=227893 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1de61bc8
"jupnp-jetty-client-228349" Id=228349 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@4f1c5d1f
Thanks! It doesn’t look like deadlock because there is no thread with lifx in one of the method signatures.
After looking at the code I think it’s most likely an exception occurred which resulted in a variable keeping track of on going scans not being set to false. So it should work again after restarting openHAB. I’ll tweak the exception handling so it shouldn’t occur in future versions.
