Anyone an Idea? The Calendar is a nextcloud calender, but I don’t think that’S related.
Log:
2017-12-18 22:41:30.498 [WARN ] [.io.caldav.internal.CalDavLoaderImpl] - A URL must be configured for calendar ‘’
2017-12-18 22:41:30.499 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.openhab.io.caldav.CalDavLoader, id=251, bundle=234/mvn:org.openhab.io/org.openhab.io.caldav/1.11.0]: Updating property CalDAV IO of configuration org.openhab.caldavio caused a problem: A URL must be configured for calendar ‘’
org.osgi.service.cm.ConfigurationException: CalDAV IO : A URL must be configured for calendar ‘’
at org.openhab.io.caldav.internal.CalDavLoaderImpl.updated(CalDavLoaderImpl.java:225) [234:org.openhab.io.caldav:1.11.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
2017-12-19 14:58:52.778 [DEBUG] [b.io.caldav.internal.CalDavActivator] - CalDav Calendar IO has been started.
2017-12-19 14:58:52.779 [DEBUG] [org.openhab.io.caldav ] - BundleEvent STARTED - org.openhab.io.caldav
2017-12-19 14:58:52.806 [DEBUG] [org.openhab.io.caldav ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.openhab.io.caldav.CalDavLoader}={service.pid=org.openhab.caldavio, component.name=org.openhab.io.
caldav.caldavloader, component.id=24, service.id=129, service.bundleid=234, service.scope=bundle} - org.openhab.io.caldav
2017-12-19 14:58:52.807 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - Update was called for CalDAV IO.
2017-12-19 14:58:52.810 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: :url
2017-12-19 14:58:52.813 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: calKinderzimmer:password
2017-12-19 14:58:52.818 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: calKinderzimmer:reloadInterval
2017-12-19 14:58:52.818 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: calKinderzimmer:url
2017-12-19 14:58:52.819 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: calKinderzimmer:username
2017-12-19 14:58:52.819 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: hauskalender:password
2017-12-19 14:58:52.820 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: hauskalender:reloadInterval
2017-12-19 14:58:52.820 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: hauskalender:url
2017-12-19 14:58:52.820 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: hauskalender:username
2017-12-19 14:58:52.825 [TRACE] [.io.caldav.internal.CalDavLoaderImpl] - processing configuration parameter: timeZone
2017-12-19 14:58:52.828 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - Overriding default timezone Europe/Berlin with Europe/Berlin
2017-12-19 14:58:52.829 [WARN ] [.io.caldav.internal.CalDavLoaderImpl] - A URL must be configured for calendar ''
2017-12-19 14:58:52.834 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.openhab.io.caldav.CalDavLoader, id=129, bundle=234/mvn:org.openhab.io/org.openhab.io.caldav/1.11.0]: Updating property CalD
AV IO of configuration org.openhab.caldavio caused a problem: A URL must be configured for calendar ''
org.osgi.service.cm.ConfigurationException: CalDAV IO : A URL must be configured for calendar ''
So, there are really old entries. But where do they come from?
Delete the contents of /var/lib/openhab2/cache and /var/lib/openhab2/tmp. For manual installations these folders are in your OH home folder under userdata. DO NOT DELETE THE FOLDERS THEMSELVES, JUST THE CONTENTS.
Deleting the content of the both directories isn’t enough?
