when building my bundle with a fresh checkout of the openhab2-addons and running
mvn clean install -DskipChecks=true it runs successful
however
mvn clean install (with cheks) fails with
[ERROR] Unable to get about.html file from https://raw.githubusercontent.com/openhab/openhab2-addons/master/src/etc/about.html : Unable to get https://raw.githubusercontent.com/openhab/openhab2-addons/master/src/etc/about.html
java.io.IOException: Unable to get https://raw.githubusercontent.com/openhab/openhab2-addons/master/src/etc/about.html
at org.openhab.tools.analysis.utils.CachingHttpClient.get (CachingHttpClient.java:69)
at org.openhab.tools.analysis.checkstyle.AboutHtmlCheck.beginProcessing (AboutHtmlCheck.java:72)
at com.puppycrawl.tools.checkstyle.Checker.process (Checker.java:210)
[ERROR] Failed to execute goal org.openhab.tools.sat:sat-plugin:0.5.0:checkstyle (default) on project org.openhab.binding.magentatv: Unable to execute mojo: An error has occurred in Checkstyle report generation. Failed during checkstyle configuration: Exception was thrown while processing /Users/markus/Dev/openhab-release.24/openhab2-addons/addons/binding/org.openhab.binding.magentatv/ESH-INF/thing/thing-types.xml: Unable to read from file: /Users/markus/Dev/openhab-release.24/openhab2-addons/addons/binding/org.openhab.binding.magentatv/ESH-INF/thing/thing-types.xml: The element type "description" must be terminated by the matching end-tag "</description>". -> [Help 1]
@Kai: it’s the MagentaTV bundle
Also if I run “mvn cleanninstall” from openhab2-addons root it failes with
[ERROR] Cannot resolve project dependencies:
[ERROR] Software being installed: org.eclipse.core.runtime 3.14.0.v20180417-0825
[ERROR] Missing requirement: org.eclipse.core.runtime 3.14.0.v20180417-0825 requires 'osgi.bundle; org.eclipse.equinox.registry [3.8.0,4.0.0)' but it could not be found
[INFO] openHAB 2 Add-ons .................................. SUCCESS [ 1.146 s]
[INFO] openHAB Add-ons .................................... SUCCESS [ 0.087 s]
[INFO] openHAB Bindings ................................... SUCCESS [ 0.112 s]
[INFO] AirQuality Binding ................................. SUCCESS [ 16.856 s]
[INFO] AirVisual Node Air Quality Monitor Binding ......... SUCCESS [ 6.143 s]
[INFO] AllPlay Binding .................................... SUCCESS [ 6.671 s]
[INFO] Amazon Dash Button Binding ......................... SUCCESS [ 6.169 s]
[INFO] Amazon Echo Control Binding ........................ SUCCESS [ 11.245 s]
[INFO] Astro Binding ...................................... SUCCESS [ 8.325 s]
[INFO] Astro Binding Tests ................................ FAILURE [ 0.585 s]
[INFO] Atlona Binding ..................................... SKIPPED
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-surefire-plugin:1.2.0:test (default-test) on project org.openhab.binding.astro.test: Execution default-test of goal org.eclipse.tycho:tycho-surefire-plugin:1.2.0:test failed: Cannot resolve dependencies of MavenProject: org.openhab.binding:org.openhab.binding.astro.test:2.5.0-SNAPSHOT @ /Users/markus/Dev/openhab-release.24/openhab2-addons/addons/binding/org.openhab.binding.astro.test/pom.xml: See log for details -> [Help 1]
