[SOLVED] Add URL link to sitemap
two years later :slightly_smiling_face:
is there a way to create a link to another sitemap which works also from the android app?
No.
Has this ability to launch a URL fro a sitemap been removed ? due to security or ?
As far as I know it has never been supported.
You could create a webview perhaps to get that.
@rlkoshak the problem is: This might work on a PC, but using webview in the iOS app doesn’t work. Dead end for me :frowning:
i am using a work around , that is only working on PC configred … will not work on any app
  1. exec is binding that helps me contorl my PC
  2. i have it also on the target PC with OH runing alwys…
  3. i connect them both with Node red , you can also use MQTT bridge of OH
if it fits you i can help with config…
