Guggsdu
(Klaus)
October 4, 2017, 7:28pm
#1
Hi there,
I added a the above mentioned device to my z-wave network, but still “Unknown Device” is shown.
Following some hints in the forum I uninstalled and reinstalled the z-wave binding. This did not solve the problem.
here the data:
Paper UI:
zwave_class_basic ROUTING_SLAVE
zwave_class_generic BINARY_SWITCH
zwave_frequent false
zwave_neighbours
zwave_version 1.1
zwave_listening true
zwave_plus_devicetype ON_OFF_POWER_SWITCH
zwave_deviceid 116
zwave_nodeid 11
zwave_routing true
zwave_beaming true
zwave_class_specific POWER_SWITCH_BINARY
zwave_manufacturer 134
zwave_devicetype 3
HabMin:
manufacturer 0086 " Aeon Labs"
type 0003:0074
Any suggestions how to solve the problem? Is the device not in the database?
Regards
Klaus
sihui
(SiHui)
October 4, 2017, 8:21pm
#2
You make look yourself at:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list
You will find:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/591
Now you need to find out which zwave binding version you are running: if it is too old that device may not work. If it is a battery operated device you need to wake it up several times.
To find out the version use the karaf console and do a bundle:list
Guggsdu
(Klaus)
October 5, 2017, 11:38am
#3
ok, that seems to be the device.
Ööööh: What is a karaf console and how can I make use of it?
(sorry - I startet to work with OH2 about 1 month ago )
When I uninstall and reinstall the z-wave-binding (as I did) - shouldn’t it be the newest version then?
Regards
Guggsdu
(Klaus)
October 5, 2017, 3:48pm
#4
Hola,
ah - ok: I found it.
z-wave binding is Version 2.1.0
is there a newer one available?
sihui
(SiHui)
October 5, 2017, 9:45pm
#6
chris
(Chris Jackson)
October 5, 2017, 10:03pm
#7
Yes, it looks like you need 2.2. This was added on July 24th, which is after 2.1 was released.
