Afterwards I configured one item to show the temperature (see screenshot below)
Next step was to chaeck the temperature on webinterface
Result: No temperature value
Found an interessting lines in openhab.log
> 09:54:56.455 [DEBUG] [veMultiLevelSensorCommandClass:298 ] - =========== Resetting init flag!
> 09:54:56.456 [DEBUG] [veMultiLevelSensorCommandClass:309 ] - ============ Requesting TEMPERATURE!
> 09:54:56.457 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn’t support get requests for MULTI_LEVEL_SENSOR
> 09:54:56.476 [DEBUG] [veMultiLevelSensorCommandClass:309 ] - ============ Requesting RELATIVE_HUMIDITY!
> 09:54:56.477 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn’t support get requests for MULTI_LEVEL_SENSOR
> 09:54:56.477 [DEBUG] [veMultiLevelSensorCommandClass:309 ] - ============ Requesting LUMINANCE!
> 09:54:56.478 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn’t support get requests for MULTI_LEVEL_SENSOR
openhab.log
> 09:54:43.580 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 255: Creating empty message of class = IsFailedNodeID (0x62), type = Request (0x00)
> 09:54:43.581 [DEBUG] [b.z.i.protocol.ZWaveController:667 ] - Enqueueing message. Queue length = 1
> 09:54:43.582 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ] - NODE 2: Node advancer - queued packet. Queue length is 1
> 09:54:43.582 [DEBUG] [WaveController$ZWaveSendThread:1374 ] - NODE 255: Response processed after 43ms/129ms.
> 09:54:43.583 [DEBUG] [WaveController$ZWaveSendThread:1258 ] - Took message from queue for sending. Queue length = 0
> 09:54:43.584 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 00 62 02 9B
> 09:54:43.585 [DEBUG] [WaveController$ZWaveSendThread:1315 ] - NODE 255: Sending REQUEST Message = 01 04 00 62 02 9B
> 09:54:43.587 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 04 01 62 00 98
> 09:54:43.588 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:43.588 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:43.589 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 01 62 00 98
> 09:54:43.590 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 04 01 62 00 98
> 09:54:43.590 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = IsFailedNodeID (0x62), type = Response (0x01), payload = 00
> 09:54:43.591 [DEBUG] [i.p.s.IsFailedNodeMessageClass:54 ] - NODE 2: Is currently marked as healthy by the controller
> 09:54:43.592 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = IsFailedNodeID (0x62), type = Request (0x00), payload = 02
> 09:54:43.593 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = IsFailedNodeID (0x62), type = Response (0x01), payload = 00
> 09:54:43.593 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=IsFailedNodeID, expected=IsFailedNodeID, cancelled=false
> 09:54:43.594 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
> 09:54:43.595 [DEBUG] [b.z.i.protocol.ZWaveController:682 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
> 09:54:43.595 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
> 09:54:43.596 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1005 ] - NODE 2: Node advancer - FAILED_CHECK: Transaction complete (IsFailedNodeID:Request) success(true)
> 09:54:43.596 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:201 ] - NODE 2: Node advancer - checking initialisation queue. Queue size 1.
> 09:54:43.597 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:207 ] - NODE 2: Node advancer - message removed from queue. Queue size 0.
> 09:54:43.597 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ] - NODE 2: Node advancer - FAILED_CHECK: queue length(0), free to send(true)
> 09:54:43.598 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - FAILED_CHECK try 1: stageAdvanced(false)
> 09:54:43.599 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:860 ] - NODE 2: Node advancer - advancing to WAIT
> 09:54:43.599 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - WAIT try 0: stageAdvanced(true)
> 09:54:43.600 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:380 ] - NODE 2: Node advancer: WAIT - Listening=false, FrequentlyListening=false
> 09:54:43.601 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:398 ] - NODE 2: Node advancer: WAIT - Still waiting!
> 09:54:43.602 [DEBUG] [WaveController$ZWaveSendThread:1374 ] - NODE 255: Response processed after 17ms/129ms.
> 09:54:56.381 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 11 00 49 84 02 0B 04 20 01 30 31 80 84 70 85 72 86 0B
> 09:54:56.383 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.383 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.384 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 11 00 49 84 02 0B 04 20 01 30 31 80 84 70 85 72 86 0B
> 09:54:56.384 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 11 00 49 84 02 0B 04 20 01 30 31 80 84 70 85 72 86 0B
> 09:54:56.385 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 02 0B 04 20 01 30 31 80 84 70 85 72 86
> 09:54:56.388 [DEBUG] [.ApplicationUpdateMessageClass:44 ] - NODE 2: Application update request. Node information received.
> 09:54:56.389 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class SENSOR_BINARY
> 09:54:56.389 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class SENSOR_MULTILEVEL
> 09:54:56.390 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class BATTERY
> 09:54:56.391 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class WAKE_UP
> 09:54:56.392 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class CONFIGURATION
> 09:54:56.393 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class ASSOCIATION
> 09:54:56.394 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class MANUFACTURER_SPECIFIC
> 09:54:56.395 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:224 ] - NODE 2: Creating new instance of command class VERSION
> 09:54:56.396 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 2: Is awake with 0 messages in the wake-up queue.
> 09:54:56.397 [DEBUG] [b.z.i.protocol.ZWaveController:682 ] - Notifying event listeners: ZWaveWakeUpEvent
> 09:54:56.398 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
> 09:54:56.398 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1028 ] - NODE 2: Wakeup during initialisation.
> 09:54:56.399 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ] - NODE 2: Node advancer - WAIT: queue length(0), free to send(true)
> 09:54:56.400 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - WAIT try 1: stageAdvanced(false)
> 09:54:56.400 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:380 ] - NODE 2: Node advancer: WAIT - Listening=false, FrequentlyListening=false
> 09:54:56.401 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:392 ] - NODE 2: Node advancer: WAIT - Node is awake
> 09:54:56.402 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:860 ] - NODE 2: Node advancer - advancing to PING
> 09:54:56.403 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - PING try 0: stageAdvanced(true)
> 09:54:56.404 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:417 ] - NODE 2: Node advancer: PING - send NoOperation
> 09:54:56.405 [DEBUG] [c.ZWaveNoOperationCommandClass:72 ] - NODE 2: Creating new message for command No Operation
> 09:54:56.405 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 2: Creating empty message of class = SendData (0x13), type = Request (0x00)
> 09:54:56.406 [DEBUG] [b.z.i.protocol.ZWaveController:985 ] - Callback ID = 2
> 09:54:56.407 [DEBUG] [b.z.i.protocol.ZWaveController:667 ] - Enqueueing message. Queue length = 1
> 09:54:56.407 [DEBUG] [WaveController$ZWaveSendThread:1258 ] - Took message from queue for sending. Queue length = 0
> 09:54:56.408 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ] - NODE 2: Node advancer - queued packet. Queue length is 1
> 09:54:56.410 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 08 00 13 02 01 00 25 02 C0
> 09:54:56.410 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = IsFailedNodeID (0x62), type = Request (0x00), payload = 02
> 09:54:56.410 [DEBUG] [WaveController$ZWaveSendThread:1315 ] - NODE 2: Sending REQUEST Message = 01 08 00 13 02 01 00 25 02 C0
> 09:54:56.411 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 84 02 0B 04 20 01 30 31 80 84 70 85 72 86
> 09:54:56.412 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=ApplicationUpdate, expected=IsFailedNodeID, cancelled=false
> 09:54:56.418 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 04 01 13 01 E8
> 09:54:56.419 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.419 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.420 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 01 13 01 E8
> 09:54:56.420 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 04 01 13 01 E8
> 09:54:56.421 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
> 09:54:56.422 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 2: Sent Data successfully placed on stack.
> 09:54:56.435 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 07 00 13 02 00 00 02 EB
> 09:54:56.436 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.436 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.436 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 13 02 00 00 02 00 00 E5
> 09:54:56.437 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 09 00 13 02 00 00 02 00 00 E5
> 09:54:56.438 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = SendData (0x13), type = Request (0x00), payload = 02 00 00 02
> 09:54:56.440 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 2: SendData Request. CallBack ID = 2, Status = Transmission complete and ACK received(0)
> 09:54:56.441 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 01 00
> 09:54:56.442 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 02 00 00 02
> 09:54:56.442 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
> 09:54:56.442 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
> 09:54:56.443 [DEBUG] [b.z.i.protocol.ZWaveController:682 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
> 09:54:56.443 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
> 09:54:56.444 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1005 ] - NODE 2: Node advancer - PING: Transaction complete (SendData:Request) success(true)
> 09:54:56.444 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:201 ] - NODE 2: Node advancer - checking initialisation queue. Queue size 1.
> 09:54:56.445 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:207 ] - NODE 2: Node advancer - message removed from queue. Queue size 0.
> 09:54:56.445 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ] - NODE 2: Node advancer - PING: queue length(0), free to send(true)
> 09:54:56.446 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - PING try 1: stageAdvanced(false)
> 09:54:56.447 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:860 ] - NODE 2: Node advancer - advancing to DETAILS
> 09:54:56.447 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - DETAILS try 0: stageAdvanced(true)
> 09:54:56.447 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:435 ] - NODE 2: Node advancer: Restored from file - skipping static initialisation
> 09:54:56.448 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:860 ] - NODE 2: Node advancer - advancing to DYNAMIC_VALUES
> 09:54:56.448 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - DYNAMIC_VALUES try 0: stageAdvanced(true)
> 09:54:56.449 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
> 09:54:56.450 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY
> 09:54:56.450 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:776 ] - NODE 2: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY
> 09:54:56.451 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:780 ] - NODE 2: Found 1 instances of SENSOR_BINARY
> 09:54:56.451 [DEBUG] [.ZWaveBinarySensorCommandClass:128 ] - NODE 2: Creating new message for application command SENSOR_BINARY_GET
> 09:54:56.452 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 2: Creating empty message of class = SendData (0x13), type = Request (0x00)
> 09:54:56.453 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking VERSION
> 09:54:56.453 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
> 09:54:56.454 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking SENSOR_MULTILEVEL
> 09:54:56.454 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:776 ] - NODE 2: Node advancer: DYNAMIC_VALUES - found SENSOR_MULTILEVEL
> 09:54:56.455 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:780 ] - NODE 2: Found 1 instances of SENSOR_MULTILEVEL
> 09:54:56.457 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn't support get requests for MULTI_LEVEL_SENSOR
> 09:54:56.477 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn't support get requests for MULTI_LEVEL_SENSOR
> 09:54:56.478 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn't support get requests for MULTI_LEVEL_SENSOR
> 09:54:56.479 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
> 09:54:56.480 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking BATTERY
> 09:54:56.481 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:776 ] - NODE 2: Node advancer: DYNAMIC_VALUES - found BATTERY
> 09:54:56.481 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:780 ] - NODE 2: Found 1 instances of BATTERY
> 09:54:56.482 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:137 ] - NODE 2: Creating new message for application command BATTERY_GET
> 09:54:56.483 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 2: Creating empty message of class = SendData (0x13), type = Request (0x00)
> 09:54:56.484 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION
> 09:54:56.485 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking WAKE_UP
> 09:54:56.486 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking BASIC
> 09:54:56.487 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:808 ] - NODE 2: Node advancer: DYNAMIC_VALUES - queued 2 frames
> 09:54:56.488 [DEBUG] [b.z.i.protocol.ZWaveController:985 ] - Callback ID = 3
> 09:54:56.489 [DEBUG] [b.z.i.protocol.ZWaveController:667 ] - Enqueueing message. Queue length = 1
> 09:54:56.490 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ] - NODE 2: Node advancer - queued packet. Queue length is 2
> 09:54:56.491 [DEBUG] [WaveController$ZWaveSendThread:1374 ] - NODE 2: Response processed after 80ms/129ms.
> 09:54:56.492 [DEBUG] [WaveController$ZWaveSendThread:1258 ] - Took message from queue for sending. Queue length = 0
> 09:54:56.492 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 13 02 02 30 02 25 03 F1
> 09:54:56.493 [DEBUG] [WaveController$ZWaveSendThread:1315 ] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 30 02 25 03 F1
> 09:54:56.501 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 04 01 13 01 E8
> 09:54:56.502 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.502 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.504 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 01 13 01 E8
> 09:54:56.504 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 04 01 13 01 E8
> 09:54:56.505 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
> 09:54:56.506 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 2: Sent Data successfully placed on stack.
> 09:54:56.518 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 07 00 13 03 00 00 02 EA
> 09:54:56.520 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.520 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.521 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 13 03 00 00 02 00 00 E4
> 09:54:56.521 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 09 00 13 03 00 00 02 00 00 E4
> 09:54:56.522 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = SendData (0x13), type = Request (0x00), payload = 03 00 00 02
> 09:54:56.522 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 2: SendData Request. CallBack ID = 3, Status = Transmission complete and ACK received(0)
> 09:54:56.523 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 02 30 02
> 09:54:56.523 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 03 00 00 02
> 09:54:56.524 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
> 09:54:56.528 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 09 00 04 00 02 03 30 03 00 C0
> 09:54:56.529 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.529 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.530 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 04 00 02 03 30 03 00 C0
> 09:54:56.531 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 09 00 04 00 02 03 30 03 00 C0
> 09:54:56.532 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 03 30 03 00
> 09:54:56.533 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 2: Application Command Request (ALIVE:DYNAMIC_VALUES)
> 09:54:56.534 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 2: Incoming command class SENSOR_BINARY
> 09:54:56.535 [DEBUG] [.ZWaveBinarySensorCommandClass:82 ] - NODE 2: Received Sensor Binary Request (v1)
> 09:54:56.536 [DEBUG] [.ZWaveBinarySensorCommandClass:102 ] - NODE 2: Sensor Binary report, type=Unknown, value=0
> 09:54:56.536 [DEBUG] [b.z.i.protocol.ZWaveController:682 ] - Notifying event listeners: ZWaveBinarySensorValueEvent
> 09:54:56.537 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
> 09:54:56.538 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 0
> 09:54:56.539 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 02 30 02
> 09:54:56.539 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 03 30 03 00
> 09:54:56.540 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
> 09:54:56.541 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
> 09:54:56.541 [DEBUG] [b.z.i.protocol.ZWaveController:682 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
> 09:54:56.541 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
> 09:54:56.542 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1005 ] - NODE 2: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true)
> 09:54:56.543 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:201 ] - NODE 2: Node advancer - checking initialisation queue. Queue size 2.
> 09:54:56.543 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:207 ] - NODE 2: Node advancer - message removed from queue. Queue size 1.
> 09:54:56.544 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ] - NODE 2: Node advancer - DYNAMIC_VALUES: queue length(1), free to send(true)
> 09:54:56.544 [DEBUG] [b.z.i.protocol.ZWaveController:985 ] - Callback ID = 4
> 09:54:56.545 [DEBUG] [b.z.i.protocol.ZWaveController:667 ] - Enqueueing message. Queue length = 1
> 09:54:56.545 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ] - NODE 2: Node advancer - queued packet. Queue length is 1
> 09:54:56.546 [DEBUG] [WaveController$ZWaveSendThread:1374 ] - NODE 2: Response processed after 52ms/129ms.
> 09:54:56.547 [DEBUG] [WaveController$ZWaveSendThread:1258 ] - Took message from queue for sending. Queue length = 0
> 09:54:56.547 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 13 02 02 80 02 25 04 46
> 09:54:56.548 [DEBUG] [WaveController$ZWaveSendThread:1315 ] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 80 02 25 04 46
> 09:54:56.556 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 04 01 13 01 E8
> 09:54:56.557 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.557 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.558 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 01 13 01 E8
> 09:54:56.559 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 04 01 13 01 E8
> 09:54:56.560 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
> 09:54:56.560 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 2: Sent Data successfully placed on stack.
> 09:54:56.572 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 07 00 13 04 00 00 02 ED
> 09:54:56.574 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:56.574 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:56.575 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 13 04 00 00 02 00 00 E3
> 09:54:56.575 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 09 00 13 04 00 00 02 00 00 E3
> 09:54:56.576 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = SendData (0x13), type = Request (0x00), payload = 04 00 00 02
> 09:54:56.577 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 2: SendData Request. CallBack ID = 4, Status = Transmission complete and ACK received(0)
> 09:54:56.578 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 02 80 02
> 09:54:56.579 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 04 00 00 02
> 09:54:56.579 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
> 09:54:59.040 [DEBUG] [eController$ZWaveReceiveThread:1528 ] - Receive Message = 01 09 00 04 00 02 03 80 03 00 70
> 09:54:59.041 [DEBUG] [eController$ZWaveReceiveThread:1452 ] - Receive queue ADD: Length=1
> 09:54:59.041 [DEBUG] [b.z.i.protocol.ZWaveController:1210 ] - Receive queue TAKE: Length=0
> 09:54:59.042 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 04 00 02 03 80 03 00 70
> 09:54:59.043 [DEBUG] [b.z.i.protocol.ZWaveController:1211 ] - Process Message = 01 09 00 04 00 02 03 80 03 00 70
> 09:54:59.043 [DEBUG] [b.z.i.protocol.ZWaveController:190 ] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 03 80 03 00
> 09:54:59.044 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 2: Application Command Request (ALIVE:DYNAMIC_VALUES)
> 09:54:59.044 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 2: Incoming command class BATTERY
> 09:54:59.045 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ] - NODE 2: Received Battery Request
> 09:54:59.045 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ] - NODE 2: Battery report value = 0
> 09:54:59.045 [DEBUG] [b.z.i.protocol.ZWaveController:682 ] - Notifying event listeners: ZWaveCommandClassValueEvent
> 09:54:59.046 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
> 09:54:59.046 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 0
> 09:54:59.047 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 02 80 02
> 09:54:59.047 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 02 03 80 03 00
> 09:54:59.047 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
> 09:54:59.048 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
> 09:54:59.048 [DEBUG] [b.z.i.protocol.ZWaveController:682 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
> 09:54:59.048 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
> 09:54:59.049 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1005 ] - NODE 2: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true)
> 09:54:59.049 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:201 ] - NODE 2: Node advancer - checking initialisation queue. Queue size 1.
> 09:54:59.049 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:207 ] - NODE 2: Node advancer - message removed from queue. Queue size 0.
> 09:54:59.050 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ] - NODE 2: Node advancer - DYNAMIC_VALUES: queue length(0), free to send(true)
> 09:54:59.050 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:333 ] - NODE 2: Node advancer: loop - DYNAMIC_VALUES try 1: stageAdvanced(false)
> 09:54:59.050 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
> 09:54:59.051 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY
> 09:54:59.051 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:776 ] - NODE 2: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY
> 09:54:59.051 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:780 ] - NODE 2: Found 1 instances of SENSOR_BINARY
> 09:54:59.051 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking VERSION
> 09:54:59.052 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
> 09:54:59.052 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking SENSOR_MULTILEVEL
> 09:54:59.052 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:776 ] - NODE 2: Node advancer: DYNAMIC_VALUES - found SENSOR_MULTILEVEL
> 09:54:59.053 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:780 ] - NODE 2: Found 1 instances of SENSOR_MULTILEVEL
> 09:54:59.053 [DEBUG] [veMultiLevelSensorCommandClass:309 ] - ============ Requesting TEMPERATURE!
> 09:54:59.053 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn't support get requests for MULTI_LEVEL_SENSOR
> 09:54:59.054 [DEBUG] [veMultiLevelSensorCommandClass:309 ] - ============ Requesting RELATIVE_HUMIDITY!
> 09:54:59.055 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn't support get requests for MULTI_LEVEL_SENSOR
> 09:54:59.056 [DEBUG] [veMultiLevelSensorCommandClass:309 ] - ============ Requesting LUMINANCE!
> 09:54:59.057 [DEBUG] [veMultiLevelSensorCommandClass:247 ] - NODE 2: Node doesn't support get requests for MULTI_LEVEL_SENSOR
> 09:54:59.058 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
> 09:54:59.059 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:773 ] - NODE 2: Node advancer: DYNAMIC_VALUES - checking BATTERY
> 09:54:59.060 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:776 ] - NODE 2: Node advancer: DYNAMIC_VALUES - found BATTERY
Can anyone help me ?
