Java Runtime Environment: Java™ SE Runtime Environment (build 1.8.0_151-b12)
openHAB version: 2.2.0
using Bindings: network, http, zwave
Issue of the topic: OH is running, HABmin, Paper UI, Basic UI and Karaf Console are operational, my old file (.items, .rule, .sitemaps, etc.) are at CONF folder, but are not used.
The reason I’ve not send any log was because i didn’t found any errors on it. At least after reinstalled OH 2.2.0 twice, while eliminating errors and making some cleaning ations on old stuff.
Things are whell discovered by HABmin and Paper UI, but no Items, Rules or Sitemaps appear despite the files are at the folders with the right permissions and ownership for openhab:openhab.
During my working hours I can´t access my system, but later this afternoon I’ll be back.
I have slightly different issues but an overall same problem.
After an upgrade using the recommended openhabian-config (same platform and configuration as listed here) I am dead in the water… cannot even connect through web access to the system. SSH is still working.
HELP!!!???
I also had feel problems connecting remotely via openHAB Cloud.
So, I find two UUID files and two SECRET files. At /var/lib/openhab2/ but also at /var/lib/openhab2/userdata/.
I’ve deleted the four files and have restarted OH. The new files where created only on /var/lib/openhab2/userdata/. But, connecting remotely still failed. I then copied both files to /var/lib/openhab2/, restarted OH and now I can connect via openHAB Cloud.
When you upgraded, did you get any prompts to overwrite configuration files with the maintainers version? If so, did you do it? You can reset everything that’s updated in the new version with the command:
Im afraid I don’t know what be causing that issue. There shouldn’t be a home directory for openhab and the apt packages do not set any. Is this a configuration that you have set yourself?
I’ve never set any any other openhab directory than the ones are according “by the book”. So, I believe it must have to do with OH 2.2.0 setup, or I had never notice that before.
Finally
After my last reinstallation, last night, I can see now some WARNing messages related with this subject:
2017-12-21 19:55:54.466 [WARN ] [.core.internal.folder.FolderObserver] - Directory 'things' does not exist in 'conf'. Please check your configuration settings!
2017-12-21 19:55:54.469 [WARN ] [.core.internal.folder.FolderObserver] - Directory 'scripts' does not exist in 'conf'. Please check your configuration settings!
2017-12-21 19:55:54.472 [WARN ] [.core.internal.folder.FolderObserver] - Directory 'items' does not exist in 'conf'. Please check your configuration settings!
2017-12-21 19:55:54.474 [WARN ] [.core.internal.folder.FolderObserver] - Directory 'persistence' does not exist in 'conf'. Please check your configuration settings!
2017-12-21 19:55:54.477 [WARN ] [.core.internal.folder.FolderObserver] - Directory 'sitemaps' does not exist in 'conf'. Please check your configuration settings!
2017-12-21 19:55:54.479 [WARN ] [.core.internal.folder.FolderObserver] - Directory 'rules' does not exist in 'conf'. Please check your configuration settings!
2017-12-21 19:55:54.551 [ERROR] [.service.internal.HttpServiceStarted] - Could not start the servlet context for context path []
java.lang.IllegalStateException: no valid keystore
