[SOLVED] After upgrade to 2.4 stable I'm flooded with java.lang.IllegalStateException
@mishakim If you believe the mqtt binding is causing the issue, and you don’t need or want it, maybe try editing /var/lib/openhab2/config/org/openhab/addons.config and remove mqtt. Note, you should probably stop the OH service before editing.
That’s exactly what I did, and it did resolve my issues.
I can also confirm that enabling legacy bindings 1.x through paperUI helped to have clear logs now.
PaperUI > Configuration > System > AddOn Management > Include Legacy 1.x Bindings
I also was running MQTT 1 and after upgrading to OH 2.4 I had a slow system with lots of 503 errors and delays while connecting and using PaperUI. Now the system calmed down and is responsive as it should be without the errors in the log.
Thanks to everybody solving this!
BR
Uwe
I also hit this issue with a clean install of 2.4 stable. It was working fine and the trigger that caused it was trying to uninstall some of the UI’s that I don’t use. To fix it I did as people have already noted as the solution and the linux commands were…
sudo rm /var/lib/openhab2/config/org/openhab/addons.config
sudo service openhab2 stop && sudo rm -rf /var/lib/openhab2/cache/* && sudo rm -rf /var/lib/openhab2/tmp/* && sudo reboot
Please note that removing the addons.config will remove all the binding that have been installed via PaperUI (and the ones added via addons file). Not a big deal, but something you might want to be aware of, just write down or take note of all the binding you currently have before removing the file. On the other hand if you add your bindings via files then you shouldn’t have this issue as OH will restore everything listed in etc/openhab2/services/addons after a restart.
Bingo!
Enabled debug logging (log:set debug org.openhab.core.karaf), and the same here mqtt1 was installing every one minute. Removed it from /var/lib/openhab2/config/org/openhab/addons.config and voila! - Openhab works much more stable!
Thanks @wborn for pointing solution!
//Marcin
This was the solution for me; I just upgraded OH on a Synology from v2.3 to v2.4 with a lot of 2.5m1 bindings.
Best, Jay
Hi guys, i have basicly the same problem. Tryed all your tips, but nothing worked yet. Would be happy to get help.
Here are my errors: (in my case three)
2019-12-11 23:32:54.087 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/sitemaps/Haus/gWohnzimmerLicht
javax.servlet.ServletException: javax.servlet.ServletException: java.lang.IllegalStateException: Request scope has been already shut down.
   at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
   at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
   at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
   at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
   at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
   at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
   at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
   at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
   at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
   at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
   at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
   at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: javax.servlet.ServletException: java.lang.IllegalStateException: Request scope has been already shut down.
   at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
   at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
   at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
   at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
   at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
   at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
   at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[?:?]
   at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[?:?]
   at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
   at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[?:?]
   at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
   at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[?:?]
   at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[?:?]
   at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[?:?]
   at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[?:?]
   at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[?:?]
   at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
   at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[?:?]
   at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[?:?]
   at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[?:?]
   at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[?:?]
   at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[?:?]
   at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[?:?]
   at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
   ... 15 more
Caused by: java.lang.IllegalStateException: Request scope has been already shut down.
   at jersey.repackaged.com.google.common.base.Preconditions.checkState(Preconditions.java:173) ~[?:?]
   at org.glassfish.jersey.process.internal.RequestScope.retrieveCurrent(RequestScope.java:239) ~[?:?]
   at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:314) ~[?:?]
   at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
   at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
   at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
   ... 15 more
2019-12-11 23:32:03.943 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/sitemaps/Haus/gWohnzimmerSzenen
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions.  They are:
1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_6,7,23861664) has been shut down
Caused by: javax.servlet.ServletException: A MultiException has 1 exceptions.  They are:
   ... 15 more
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions.  They are:
   at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?]
   at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?]
   at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?]
   at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[?:?]
   at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[?:?]
   at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[?:?]
   ... 15 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_6,7,23861664) has been shut down
   at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
   at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
   at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
   at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
   at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
   ... 15 more
>2019-12-11 23:32:01.408 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/sitemaps/Haus/Haus
... 15 more
... 15 more
... 15 more
I get the error multiple times and i really don’t know why. I tryed it with deliting the addons.config file and a completly new instalation of all addons, but i still get the error.
Here’s my addons.config file:
binding="knx,astro,hue,openweathermap,weather1"
legacy=B"true"
misc="restdocs,market,hueemulation,openhabcloud"
package="expert"
remote=B"true"
service.pid="org.openhab.addons"
transformation="map,regex,xslt,exec,javascript,scale,xpath,jsonpath"
ui="classic,basic,paper,habpanel,habmin"
Hopefully one o you can help my with this issue. Hope for a quick response, cause my complet Smart Home is down at the moment causing this.
What platform and Java version?
That’s generally originating from a UI - something like a UI or Sitemap left running from before changes to the host system is a common cause e.g. forgotten browser window or tablet.
My system is running at this platform:
Platform = Raspberry Pi 3 Model B Rev 1.2
Java version:
openjdk version “1.8.0_222”
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222 -b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation)
That is the current version of Java on the Pi. I have that on my test server running 2.5RC1
