[SOLVED] Alexa integration and CurrentTemperature issue (Italian Skill)
Hi all,
I’m just playing with Alexa in Italian (today they published the Italian Skill).
In my Living Room I have a Netatmo module and a Danfoss Thermostat Valve. My items:
/* Groups */
Group gFF_LivingRoomThermostat "Radiatore" (gRadiators) [ "Thermostat" ]
/* Target Temperature */
//Number Alexa_LivingRoom_Radiator_CurrentTemperature "Temperatura attuale" (gLivingRoomThermostat) [ "CurrentTemperature" ]
Number Alexa_LivingRoom_Radiator_TargetTemperature "Temperatura" (gFF_LivingRoomThermostat) [ "TargetTemperature" ]
/* Current Temperatures */
Number Alexa_LivingRoom_Temperature "Temperatura [%.1f °C]" (gFF_LivingRoom) [ "CurrentTemperature" ]
Both items are linked to the right channel respectively via PaperUI.
I can set the temperature on my Thermostat without any issue. But when I ask (translated in english) “Alexa, tell me the temperature in living room” the answer is “There are more than one thermostat in the Living Room … ask me again adding the name of the device”
I’m stuck :frowning: What I’m missing?
thanks
Andrea
Does it work if you remove the group association from the item?
/* Groups */
Group gFF_LivingRoomThermostat "Radiatore" [ "Thermostat" ]
Number Alexa_LivingRoom_Temperature "Temperatura [%.1f °C]" [ "CurrentTemperature" ]
Same issue
Try
Number LivingRoomThermostat "Radiatore" [ "Thermostat" ]
@ariela EDIT
Your just wanting the room temp not the thermostat setting correct?
If so try removing the temp item from the group.
What do you think if I “mask” somehow the current temperature via Netatmo as the current temperature was collected via thermostat?
I mean:
Number Alexa_LivingRoom_Temperature "Temperatura [%.1f °C]" (gLivingRoomThermostat) [ "CurrentTemperature" ]
as
Alexa_LivingRoom_Temperature -> Netatmo
Alexa_LivingRoom_Radiator_TargetTemperature -> Danfoss
is what I did … nothing
On the other hand, change the group to number is not permitted (you need to have a group per thermostat)
With a rule and a proxy item maybe?
Rough example:
Added Item:
Number Your_Proxy_Item "Temperatura [%.1f °C]" [ "CurrentTemperature" ]
Rule
rule "temp"
	Member of gFF_LivingRoomThermostat changed
    Your_Proxy_Item.postUpdate(Alexa_LivingRoom_Temperature.state)
Solved!
I think is much easier if you create another item (like me) pointing to the same Netatmo channel, but assigned to the Thermostat group as “CurrentTemperature”.
:slight_smile:
Good to hear,:smiley: and thanks for marking the topic solved.:+1:
If you would please post your working items file. It will be a good example for anyone else that stumbles across a similar issue.
Should I post something in “Tutorials”?
You can but please do a through search on the forum to make sure someone hasn’t already done so. Sometimes it can be very time consuming scrolling thru all the post looking for a solution, hence the,:+1: for adding [Solved] to the title, and I find most people look at the Tutorials section for large scale solutions. Simply posting what works is a good contribution but I’ll stop rambling now,:laughing: and leave the decision up to you.
EDIT: If you decide to create a tutorial please provide a link in this topic or post your working solution here as well.
Title: The Power of Channels :slight_smile:
ISSUE
If you have two sensors reporting the Temperature in the same room (like in my case a Netatmo device and a Danfoss Thermostat valve), Alexa most likely won’t be able to answer the question “what’s the temperature in the room?” because for Alexa there are two thermostats and the situation is unclear.
SOLUTION
The idea is to consider what device for you is more reliable for “CurrentTemperature”. In my case Netatmo. So I’ve created a Thermostat group, with two items pointing in PaperUI to Danfoss setpoint channel for the target temperature and to Netatmo temperature for the current temperature.
/* Groups */
Group gFF_LivingRoom_Thermostat "Radiatore" (gRadiators) [ "Thermostat" ]
Number Alexa_LivingRoom_Radiator_TargetTemperature "Temperatura" (gFF_LivingRoom_Thermostat) [ "TargetTemperature" ]
Number Alexa_LivingRoom_Temperature "Temperatura [%.1f °C]" (gFF_LivingRoom_Thermostat) [ "CurrentTemperature" ]
The “original” items in my case are the following
Number Netatmo_LivingRoom_Temperature "Temperature [%.1f °C]" (gFF_LivingRoom, gTemperature, gAVGTemperature, gFF_AVGTemperature, gChart, gHistory)
Number Danfoss_LivingRoom_Radiator_Temperature "Radiator Setpoint [%d]" (gFF_LivingRoom, gRadiators)
but creating two new items I’ve solved the “CurrentTemperature” issue, and also simplified how to to manage, like in my case, a main configuration in english and the “alexa part” with labels in my native language (italian).
Hope this helps
Andrea
