Hi Guys,
since my first assumption was wrong ([SOLVED] Remove Tags from items), i’ve decided to create a new thread, since I couldn’t find a solution in all of the other threads with this topic.
I am running OpenHab 2.3 (release) on an Raspi model 3.
I’ve just got a fire hd tablet and currently i am trying to get the alexa skill working.
- Connection to myopenhab is working (i am able to access the REST API from myopenhab.org/rest/items
- Alexa skill is installed and it is also listed as an application on myopenhab.org
- I currently have ONE item (for debugging i’ve deleted the other items) which i am trying to control:
Switch AlexaTest "AlexaTest" [ "Lighting" ]
The REST API from myopenhab.org lists also this item:
[{"link":"https://myopenhab.org/rest/items/AlexaTest","state":"NULL","editable":false,"type":"Switch","name":"AlexaTest","label":"AlexaTest","tags":["Lighting"],"groupNames":[]}]
But still, the alexa skill is unable to find this item.
I am stuck now, since i have noe idea what could possibly be wrong.
FireHD Tablet is on the same network as the openhabian setup, and openhab is running on port 8080.
Any advice would highly be appreciated.
