It’s a binding from the market place
You first need to enable the market place
PaperUI/Addons/Misc/Eclipse IoT Market - Install
Go back to Bindings and refresh with the round arrow thing at the top right
Then you should be able to see the amazon echo binding
Thanks,
that was the hint.
Binding is installed now. But still not working. I will follow this up in the binding thread.
Thanks for your help.
You should move from RC1 to the Release.
… and then the binding is available without the marketplace
Thanks for the hint. I tried, but with
apt-get update / upgrade
it doesn´t install to the newest version. The system always tell me, it is already the newest version installed.
If I change manually to the specified version, I will get not info about newer version. What might be the correct solution for that?
Check your openhab2.list:
sebzim@openHAB:~ $ cat /etc/apt/sources.list.d/openhab2.list
deb https://dl.bintray.com/openhab/apt-repo2 testing main
Look good. But there is no update available.
Nope. You are on the testing branch. You need to switch to stable
for the 2.3 release or unstable
for 2.4 snapshot.
You are right. But this doen´t change anything.
I tried also with stable and also again with update / upgrade.
No newer version available.
Sorry, out of ideas, I don’t use the apt repository …
Try
sudo apt-cache madison openhab2
What do you get?
openhab2 | 2.3.0-1 | https://dl.bintray.com/openhab/apt-repo2/ stable/main armhf Packages
openhab2 | 2.2.0-1 | https://dl.bintray.com/openhab/apt-repo2/ stable/main armhf Packages
openhab2 | 2.1.0-1 | https://dl.bintray.com/openhab/apt-repo2/ stable/main armhf Packages
openhab2 | 2.0.0-1 | https://dl.bintray.com/openhab/apt-repo2/ stable/main armhf Packages
Ok so you are on the last stable release and it still doesn’t work.
Are you willing to try SNAPSHOT
echo 'deb https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
sudo apt-get update
sudo apt-get install openhab2
sudo apt-get install openhab2-addons
Hmm.
I want to avoid the snapshot.
Did this during the last month and I crashed my complete install in total 3 times with broken snapshots. No recovery was possible.
So I would prefer to stay with stable versions…
Did you try?
sudo apt-get --reinstall openhab2
sudo apt-get --reinstall openhab2-addons
also not working.
I tried this one
sudo apt-get install openhab2=2.3.0-1
He told me, I was doing an downgrade…
We will see, how it work. It is now installing…
Downgrading to 2.3.0-1??
You must have been on some snapshot
Sure?
It was coming from here
It is running.
Also the Echo binding works now.
Thanks for help.
I’m running Synology openHAB Snapshot 2.3.0.001 and I’m located in the US.
My Amazon Things stay in Uninitialization state
The testing URL shows this below http://openhab:8080/amazonechocontrol/
Amazon Echo Control RC3
No Account thing created
I’m concerned doing a manual Snapshot upgrade would bust the installation on Synology.
Any help would be appreciated.
