[SOLVED] Analyzing Temperature and Humidity in OpenHab
I would suggest sending data in JSON format, so that a JSON transform can be used to extract data to an item. I copied the idea from this thread, which shows a python script to read miFlora sensors and sends them via MQTT. Then the item definition contains the JSON transform.
Lionello
