bruce
(sir)
July 20, 2018, 10:07pm
#1
hello,
i would like have the position off my roller schutter. With knx ets i have a gad with this position (5.001 percentage) but i can’t have a value with sitemap or habpanel.
in items :
Number volet_sdb2 "sdb2 [%d %%] { knx=“1/1/0” }
in sitemap :
text item=volet_sdb2 label="volet sdb2 [%d %%]
have you got an idea.
thank you very much.
bruce
hr3
(Harry)
July 21, 2018, 3:07am
#2
Number volet_sdb2 "sdb2 [%d %%]" { knx=“1/1/0” }
Text item=volet_sdb2 label="volet sdb2 [%d %%]"
or
Default item=volet_sdb2
PS: What editor do you use?
bruce
(sir)
July 21, 2018, 10:43am
#3
i use pluma, and inkscape for my visualisation.
have you got the correct sentence to put in items file and in inkscape. with my température no problèm so i think it’s the same with a number.
with sitemap the temperature do not work
thanks
hr3
(Harry)
July 21, 2018, 10:52am
#4
Vs Code has a syntax-ceck for openHAB.
What about volet_sdb2 and please post the code for the temperature-item. What does not work?
bruce
(sir)
July 21, 2018, 4:42pm
#5
i install vs code and nothing wrong
i solved my problèm with temperature (item in sitemap was wrong)
now i alway a problèm with my roller shutter. the DPT is 5.001 percentage, the flags is :communication, read an transmission.
for the items :
Number volet_sdb2 “sdb2 [%d %%]” { knx=“1/1/0” }
and sitemap
Text item=volet_sdb2 label=“volet sdb2 [%d %%]”
i’m don’t know very well openhab, could you tell me how i can see (i think in karaf consol) if my roller shutter send the percentage to openhab.
thanks
hr3
(Harry)
July 21, 2018, 5:04pm
#6
Look in the events.log oder use LogViewer
I‘m new to this community. First i want to thank you for your great work. I‘m using raspian for my home automation and everything runs fine.
Now my question:
I have updated my Raspian from inside the sudo openhabian-config. Here the screenshot of the updated version.
Screenshot Raspian
[image]
In the openHAB2 Welcome page the UI for LogViewer is missing.
[image]
In Paper UI the User Interface is missing too so I can not install it.
[image]
I installed the optional component via the Con…
In case of Rollershutter, just use the Rollershutter Item, as it’s designed for Rollershutters. With knx1:
Rollershutter volet_sdb2 "sdb2 [%d %%]" {knx="1/1/2, 1/1/3, 1/1/1 + <1/1/0"}
where
1/1/2 = Move UP/DOWN
1/1/3 = Step UP/DOWN
1/1/1 = Command absolute position
1/1/0 = State absolute Position (Requestable)
For read/write in sitemap, use
Switch item=volet_sdb2
For read-only in sitemap, use
If you want to use a DPT5.001 in a Number Item, I think you have to set the DPT:
Number myNumberItem "Percentage is [%d %%]" {knx="5.001:1/1/0"}
But be aware that only one Item will be updated from a knx group telegram when using the same GA in different Items.
bruce
(sir)
July 22, 2018, 5:03pm
#8
thank you verry much it’s work.
so i put in item :
Number volet_sdb2 “Percentage is [%d %%]” { knx=“5.001:1/1/0” }
Yes. But be aware that GA 1/1/0 must not apear in any other knx bound item.
Number volet_sdb2 "Percentage is [%d %%]" {knx="5.001:1/1/0"}
bruce
(sir)
July 23, 2018, 10:10pm
#10
ok i just need one and it’s work verry good
perhaps you can help with the percentage and floorplan. i would like drawbar for know where is the rollershuter. i know how hiden a draw when the percentage is equal to 10% for exemple. i want hidden or show a drawbar when it’s < or > or equal to 10. do you know how.
{“switch-on”: itemState(volet_sdb2’)==‘10’} (but how <>or =)
i don’t know where i can find exemple of syntax for my css.file or my objects, i know hidden but i don’t show
thanks a lot
Sorry, I dont know how to configure HABmin…
