Hi
the problem is that is stuck on charging icon, it not said that is unable to connect (and on left panel i can see my sitemaps list), it try to charge the sitemap continuously.
most likely a fubar nginx configuration…
by the way: why you go via nginx locally?
i don’t like to leave access to my openhab without encrypted password even in locally in case of someone hack my wifi.
and did you stop OH2 from listening to the LAN? (or just changed the default ports)
anyway, you have a broken nginx configuration. fix it
i’ve block def. port with firewall, do you think is nginx? because if i try to connect from my pc i’ve no problem to access from custom https port
it could be an issue with the mobile app… but if you can’t produce any logs… it’s going to be hard to debug this
another option is for you to post the configs so other people can replicate this and debug it
And here we go:
server {
listen 10445 default_server ssl;
ssl_certificate /etc/ssl/openhab.crt;
ssl_certificate_key /etc/ssl/openhab.key;
server_name openhab;
error_log /etc/nginx/logs/error1.log;
#access_log c:/nginx/logs/access1.log;
location / {
proxy_pass http://localhost:8080;
auth_basic “Username and Password Required”;
auth_basic_user_file /etc/nginx/.htpasswd;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /var/www/nginx-default;
I remark that all happened after app update
Thanks anyway for your replies.
Try the following (disable ssl & auth as a first step):
server {
listen 10445;
location / {
proxy_pass http://127.0.0.1:8080;
proxy_buffering off;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
if this works, bring back auth:
server {
listen 10445;
location / {
# Auth settings
auth_basic "Username and Password Required";
if this works, bring back ssl
First step already not work.
not even from a LAN PC?
any errors in /etc/nginx/logs/error1.log
did you change the mobile app Local server URL settings to not use ssl and auth when they connect to http://nginx_ip:10445
And here i drop the bomb:
After the app update tht option about “not use ssl” totally disappear, i thought that now the app is able to detect when use it or not
just fyi: this is the thread that the mobile app will send you to when you press the ? button next to the SSL Certs configuration.
Note: this tutorial is how to configure Client side Certs (not Server side which are configured in nginx). I just post it to see an example of a working configuration of reverse proxy. Disregard both client and server certs for now until you get the basic reverse proxy functionality working.
well, if you use http
in the URL, it won’t use SSL (only with https
you right, my bad.
Still no luck , tried http://ipaddress:10445, the app reply:
http://ipaddress:10445/rest Exception Stack java.io.IOexception: bad request
yeah, that the page
try:
proxy_pass http://127.0.0.1:8080/;
(with a slash at the end)…
can you access this URL (http://ipaddress:10445
) from a LAN PC?
here the config, now i can’t access from lan PC neither
server {
listen 10445;
location / {
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_$
UPDATE:
I’m unable to acces it in http, but still i can in https even without cert. configuration
i’ve figured out.
cleaning up nginx folder before reinstall, i found an old config file inside sites-enabled that make conflict.
Sorry to waste your time, have a nice day.
I see that there’s some confusion: The “Ignore ssl cert” options disappeared, but now you’ll be asked to accept the certificate manually if it’s not trusted. That’s way more secure than trusting every cert.
The remaining option has nothing to do with server side certificates, but with a ssl client certificate. That can be used to authenticate at the server.
edit: yes… it is confusing because I was replying to bassysta about SSL certs and didn’t clarify this aspect (client vs server side)
I have edited the post above ! thanx
