Hi.
OH2 and MQTT was working fine.
Did an apt-get update and apt-get upgrade, and found that openhab2 was not communicating with MQTT.
found that in mqtt-eventbus.cfg, the mosquitto entry was on another line, eg
# Name of the broker as it is defined in the openhab.cfg. If this property is not available, no event bus MQTT binding will be created.
broker=
mosquitto
So I fixed that up, and now was not getting any errors. But Openhab will still not communicate with mqtt / mosquitto.
mqtt.cfg :
mosquitto.url=tcp://127.0.0.1:1883
mosquitto.clientId=OpenHab
mosquitto.retain=true
home.items :
Group All
Group gINSIDE (All)
Group gOUTDOOR (All)
Group gGARAGE (All)
//GRP GroupName Description/Title Icon Where
Group MasterBedroom "Master Bedroom" <bedroom> (gINSIDE)
Group Bedroom2 "Bedroom 2" <bedroom> (gINSIDE)
Group MasterEnsuite "Master Ensuite" <bath> (gINSIDE)
Group Bathroom2 "Bathroom 2" <bath> (gINSIDE)
//Group Garage "Garage" <garage> (gGARAGE)
/* Lights */
Switch Light_MasterBedroom "Downlighers" (MasterBedroom,Lights)
Switch Light_Bedroom2 "Downlighers" (Bedroom2,Lights) {mqtt=">[mosquitto:/bedroom2/switch1:command:OFF:0],>[mosquitto:/bedroom2/switch1:comma
nd:ON:1],<[mosquitto:/bedroom2/switch1:state:MAP(onoff.map)]", autoupdate="false"}
Switch Light_MasterEnsuite "Ceiling" (MasterEnsuite,Lights)
Switch Light_Bathroom2 "Ceiling" (Bathroom2,Lights)
/* Garage */
Number Temperature "Temperature [%.2f F]" <temperature> (Garage) {mqtt="<[mosquitto:/garage/temp1:state:default]"}
Number Humidity "Humidity: [%.2f]%" <humidity> (Garage) {mqtt="<[mosquitto:/garage/humid1:state:default]"}
Number LightLevel "Light: [%.2f]%" <light> (Garage) {mqtt="<[mosquitto:/garage/lightlevel1:state:default]"}
Switch Garagedoor "Garage Door" <garagedoor> (gGARAGE) {mqtt=">[mosquitto:/garagedoor/switch1:command:OFF:0],>[mosquitto:/garagedoor/s
witch1:command:ON:1],<[mosquitto:/garagedoor/reedswitch1:state:MAP(onoff.map)]", autoupdate="false"}
openhab.log grepped for mqtt
2017-02-25 20:42:45.692 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mosquitto'
2017-02-25 20:48:53.728 [ERROR] [org.apache.felix.configadmin ] - Cannot use configuration org.openhab.mqtt for [org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService, id=295, bundle=191/mvn:org.openhab.io/org.openhab.io.transport.mqtt/1.10.0-SNAPSHOT]: No visibility to configuration bound to mvn:org.openhab.action/org.openhab.action.mqtt/1.10.0-SNAPSHOT
mosquitto log :
1488049161: Received PINGREQ from client-1c6adc
1488049161: Sending PINGRESP to client-1c6adc
1488049165: Received PUBLISH from client-garagedoor (d0, q0, r0, m0, '/garage/temp1', ... (3 bytes))
1488049165: Received PUBLISH from client-garagedoor (d0, q0, r0, m0, '/garage/humid1', ... (3 bytes))
1488049165: Received PUBLISH from client-garagedoor (d0, q0, r0, m0, '/garage/lightlevel1', ... (5 bytes))
1488049166: Received PINGREQ from client-garagedoor
1488049166: Sending PINGRESP to client-garagedoor
1488049176: Received PINGREQ from client-1c6adc
1488049176: Sending PINGRESP to client-1c6adc
Thanks.
P
