- Platform information:
- Hardware:
raspberry pi 3 - OS:
Raspian Jessie - Java Runtime Environment:
1.8.0_121 - openHAB version:
OH2.3 snapshot
- Hardware:
- Issue of the topic:
apt-get upgrade fails on openhab2_addons:
Reading package lists... Done
Building dependency tree
Calculating upgrade... The following packages were automatically installed and are no longer required:
libc-ares2 libxrender1
Use 'apt-get autoremove' to remove them.
Done
The following packages will be upgraded:
ca-certificates curl file git git-man gnupg gpgv libarchive-zip-perl libcups2 libcurl3 libcurl3-gnutls libfaad2 libgcrypt20 libicu52 libidn11 libldap-2.4-2 libmad0 libmagic1 libmosquitto1 libmp3lame0
libmysqlclient18 libncurses5 libncursesw5 libprocps3 libssl1.0.0 libtinfo5 libvorbis0a libvorbisenc2 libvorbisfile3 mosquitto mosquitto-clients mysql-client-5.5 mysql-common mysql-server
mysql-server-5.5 mysql-server-core-5.5 ncurses-base ncurses-bin ncurses-term openhab2 openhab2-addons openhab2-addons-legacy openssl patch perl perl-base perl-modules procps python-mosquitto tzdata
wget wpasupplicant
52 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 155 MB/260 MB of archives.
After this operation, 6556 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 https://dl.bintray.com/openhab/apt-repo2/ stable/main openhab2-addons all 2.3.0-1 [155 MB]
Err https://dl.bintray.com/openhab/apt-repo2/ stable/main openhab2-addons all 2.3.0-1
GnuTLS recv error (-9): A TLS packet with unexpected length was received.
E: Failed to fetch https://dl.bintray.com/openhab/apt-repo2/pool/main/2.3.0/openhab2-addons_2.3.0-1_all.deb GnuTLS recv error (-9): A TLS packet with unexpected length was received.
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I’ve tried both Stable and snapshot, current content of /etc/apt/sources.list.d/openhab2.list:
deb https://dl.bintray.com/openhab/apt-repo2 stable main
Any clues?
BR,
/Janne
