i am using the latest OpenHub2 on my Raspbian 3.
I try to connect to an CUL868 and an old ASH 2200 temperature and humidity sensor.
The CUL ist connect directly at /dev/ttyACM0 but i am to stupid to get a running solution with the documentation and the docs i found in the internet.
Maybe you can give me some hints about that.
This night i was successfull in around 15 Minutes to install FHEM with this setup and it works perfectly until this morning. But i want to use it with OpenHub2.
Thanks for any help / advice.
Maybe you have any tutorial where i can go straigt forward.
PS: I installed it manually per dkpg at the latest Debian Buster.
PPS: I tryed to solved it via Serial1. But for me it was not working.
according to this information you were able to get decoded values out of FHEM.
How was this setup ? Any hint to the script that is used for that ? Having a look to the source code should help how to decode the string.
Yesterday i solved my situation with a workaround.
Because FHEM is working fine with the sensor and the CUL-Device, i decided to read the sensor via FHEM, log the measured values in a log file and with openhab2, 2 shell-scripts and the Excec-Binding i can read and place these values in the HubPanel. It’s working like a charme - but with a little overhead.
in case you are interested I can have a look to the perl module and provide the code that is required to translate/transform/decode the value in openhab
thanks for your offer. I think for this old kind of hardware only for me it’s not so important.
When the situation will make me crazy i will find another solution or will step into the perl code.
For the moment it’s ok for me. Spent your time for more valuable things.
