Hardware: Intel Q9650 on Dell 0G261D motherboard
OS: Ubuntu 18.04.1 LTS
JRE: OpenJDK 1.8.0_192
OpenHAB 2.5.1-2
I’ve added some offset channels into an Astro thing:
Thing astro:sun:home [ geolocation="xx.xxx,-xx.xxx,xxx", interval=600 ] {
Channels:
Type rangeEvent : rise#event [
offset=-40
Type rangeEvent : set#event [
offset=-30
The channels show in PaperIU but in the logs are the entries:
2020-02-17 18:43:39.668 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'astro.things'
2020-02-17 18:51:31.285 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.things'
2020-02-17 18:51:31.319 [ERROR] [o.internal.handler.AstroThingHandler] - Can't update state for channel astro:sun:home:rise#event : org.openhab.binding.astro.internal.model.Range.getEvent()
java.lang.NoSuchMethodException: org.openhab.binding.astro.internal.model.Range.getEvent()
at java.lang.Class.getMethod(Class.java:1786) ~[?:1.8.0_242]
at org.openhab.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:97) ~[?:?]
at org.openhab.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:100) ~[?:?]
at org.openhab.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:88) ~[?:?]
at org.openhab.binding.astro.internal.util.PropertyUtils.getState(PropertyUtils.java:53) ~[?:?]
at org.openhab.binding.astro.internal.handler.AstroThingHandler.publishChannelIfLinked(AstroThingHandler.java:155) ~[?:?]
at org.openhab.binding.astro.internal.handler.AstroThingHandler.channelLinked(AstroThingHandler.java:228) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:267) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_242]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_242]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_242]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_242]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_242]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_242]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
2020-02-17 18:51:31.323 [ERROR] [o.internal.handler.AstroThingHandler] - Can't update state for channel astro:sun:home:set#event : org.openhab.binding.astro.internal.model.Range.getEvent()
2020-02-17 18:51:31.327 [INFO ] [enhab.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2020-02-17 18:51:31.337 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 600 seconds
2020-02-17 18:51:31.358 [INFO ] [enhab.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:home
2020-02-17 18:51:31.365 [INFO ] [enhab.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2020-02-17 18:51:31.367 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:moon:home every 600 seconds
2020-02-17 18:51:31.391 [INFO ] [enhab.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:home
2020-02-17 18:51:31.372 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 600 seconds
2020-02-17 18:51:31.409 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:moon:home every 600 seconds
2020-02-17 18:51:32.422 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'astro.things'
I’ve also created items off of the Range events in PaperUI and put them into the sitemap but I’m sure that’s not what’s contributing to the error…
