Right after starting OH, three warnings are thrown by the Astro binding:
2018-10-14 12:28:00.023 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/sun.xml' in module 'org.eclipse.smarthome.binding.astro' could not be parsed: The XmlConfigDescriptionProvider must not be null!
java.lang.IllegalArgumentException: The XmlConfigDescriptionProvider must not be null!
at org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlProvider.<init>(ThingTypeXmlProvider.java:81) ~[?:?]
at org.eclipse.smarthome.core.thing.xml.internal.XmlThingTypeProvider.createDocumentProvider(XmlThingTypeProvider.java:163) ~[?:?]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.acquireXmlDocumentProvider(XmlDocumentBundleTracker.java:180) ~[100:org.eclipse.smarthome.config.xml:0.10.0.201809271800]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingObject(XmlDocumentBundleTracker.java:205) ~[100:org.eclipse.smarthome.config.xml:0.10.0.201809271800]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:351) [100:org.eclipse.smarthome.config.xml:0.10.0.201809271800]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:337) [100:org.eclipse.smarthome.config.xml:0.10.0.201809271800]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$4(XmlDocumentBundleTracker.java:332) [100:org.eclipse.smarthome.config.xml:0.10.0.201809271800]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [100:org.eclipse.smarthome.config.xml:0.10.0.201809271800]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-10-14 12:28:00.136 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/moon.xml' in module 'org.eclipse.smarthome.binding.astro' could not be parsed: The XmlConfigDescriptionProvider must not be null!
2018-10-14 12:28:00.249 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/channels.xml' in module 'org.eclipse.smarthome.binding.astro' could not be parsed: The XmlConfigDescriptionProvider must not be null!
As I really hate unexplained messages in logging, I wonder what causes this. I already uninstalled and reinstalled the binding.
The thing configuration is as simple as can be:
astro:sun:home [ geolocation="51.XXX123,4.XXX553", interval=300]
astro:moon:home [ geolocation="51.XXX123,4.XXX553", interval=300]
(replaced numbers with X for privacy reasons)
I run OH 2.4.0-SNAPSHOT Build #1379.
