I have this strange problem all off a sudden where my astro-binding rule doesn’t work anymore. I have a simple rule that turns on my dimmer light outside to 100 in the evening and turns it off again in the morning. This has worked for weeks and now when I added some other rules for radio purposes it doesn’t seem to work anymore.
Rules:
rule "Zons ondergang regel"
Channel 'astro:sun:local:set#event' triggered START
sendCommand(SW_Buitenlamp, 100)
rule "Zons opkomst regel"
Channel 'astro:sun:local:civilDawn#event' triggered START
sendCommand(SW_Buitenlamp, 0)
Items:
Switch Milight_TVLamp_G1_State "TVLamp Aan/Uit" (AlleLichten) {channel="espmilighthub:rgb_cct:001:0x17953:level"}
Dimmer Milight_TVLamp_G1_Level "TVLampHelder [%d %%]" {channel="espmilighthub:rgb_cct:001:0x17953:level"}
Dimmer Milight_TVLamp_G1_CTemp "TVLamp Wit" {channel="espmilighthub:rgb_cct:001:0x17953:colourtemperature"}
Color Milight_TVLamp_G1_Hue "TVLampKleur" ["Lighting"] {channel="espmilighthub:rgb_cct:001:0x17953:colour"}
String Milight_TVLamp_G1_Cmd "Command to Send" {channel="espmilighthub:rgb_cct:001:0x17953:bulbcommand"}
Switch Milight_TVLamp_G1_SndCmd "Send Command" {channel="espmilighthub:rgb_cct:001:0x17953:sendbulbcommand"}
Dimmer SW_Buitenlamp "Buitenlamp" {channel="zwave:device:a5af8125:node5:switch_dimmer1"}
In the logs I see the astro triggers but the item is not changed:
2019-05-06 20:56:34.936 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T20:55:34.902+0200 to 2019-05-06T20:56:34.907+0200
2019-05-06 20:57:34.944 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T20:56:34.907+0200 to 2019-05-06T20:57:34.911+0200
2019-05-06 20:58:34.946 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T20:57:34.911+0200 to 2019-05-06T20:58:34.917+0200
2019-05-06 20:59:34.983 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T20:58:34.917+0200 to 2019-05-06T20:59:34.958+0200
2019-05-06 21:00:34.985 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T20:59:34.958+0200 to 2019-05-06T21:00:34.962+0200
2019-05-06 21:01:35.004 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:00:34.962+0200 to 2019-05-06T21:01:34.966+0200
2019-05-06 21:02:00.006 [vent.ChannelTriggeredEvent] - astro:sun:local:daylight#event triggered END
2019-05-06 21:02:00.009 [vent.ChannelTriggeredEvent] - astro:sun:local:set#event triggered START
2019-05-06 21:02:34.995 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:01:34.966+0200 to 2019-05-06T21:02:34.973+0200
2019-05-06 21:03:35.000 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:02:34.973+0200 to 2019-05-06T21:03:34.977+0200
2019-05-06 21:04:35.009 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:03:34.977+0200 to 2019-05-06T21:04:34.983+0200
2019-05-06 21:05:35.016 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:04:34.983+0200 to 2019-05-06T21:05:34.988+0200
2019-05-06 21:06:00.006 [vent.ChannelTriggeredEvent] - astro:sun:local:set#event triggered END
2019-05-06 21:06:00.011 [vent.ChannelTriggeredEvent] - astro:sun:local:civilDusk#event triggered START
2019-05-06 21:06:35.017 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:05:34.988+0200 to 2019-05-06T21:06:34.994+0200
2019-05-06 21:07:35.029 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:06:34.994+0200 to 2019-05-06T21:07:35.004+0200
2019-05-06 21:08:35.039 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:07:35.004+0200 to 2019-05-06T21:08:35.008+0200
2019-05-06 21:09:35.040 [vent.ItemStateChangedEvent] - Date changed from 2019-05-06T21:08:35.008+0200 to 2019-05-06T21:09:35.014+0200
When I change the item manually in the sitemap it does work, this is the log from the manual action:
2019-05-06 21:27:26.945 [ome.event.ItemCommandEvent] - Item 'SW_Buitenlamp' received command 100
2019-05-06 21:27:26.958 [nt.ItemStatePredictedEvent] - SW_Buitenlamp predicted to become 100
2019-05-06 21:27:26.989 [vent.ItemStateChangedEvent] - SW_Buitenlamp changed from 0 to 100
Any ideas?
