[SOLVED] BACnet Binding errors "Could not set read property [FAILED toString()]"
The BACnet Binding works but i´m getting the following stack trace errors:
13:34:00.595 [INFO ] [smarthome.event.ItemStateChangedEvent] - Outside_Humidity changed from 51.700000762939453125 to 51.5
13:34:00.823 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
at org.code_house.bacnet4j.wrapper.ip.BacNetIpClient.getPropertyValue(BacNetIpClient.java:179) [242:org.openhab.binding.bacnet:1.11.1.201801300121]
at org.openhab.binding.bacnet.internal.queue.ReadPropertyTask.run(ReadPropertyTask.java:30) [242:org.openhab.binding.bacnet:1.11.1.201801300121]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
What is you item definition. Did you add a unit to the item?
Number Outside_Temperature "Aussentemperatur" <temperature> ["CurrentTemperature"] {bacnet="device=1337,type=analogInput,id=3"}
Number Outside_Humidity "Feuchtigkeit" <temperature> {bacnet="device=1337,type=analogInput,id=4"}
Number Regenmelder "Regenmelder" {bacnet="device=1337,type=binaryInput,id=1"}
//Niveau
Number Zisterne_Fuellstand "Zisterne Fuellstand" {bacnet="device=1337,type=analogInput,id=8"}
Number Zisterne_Sensor_Winkel "Zisterne Sensor Winkel" {bacnet="device=1337,type=analogInput,id=9"}
Number Wasserwerk_Ueberwachung "Wasserwerk Ueberwachung" {bacnet="device=1337,type=binaryInput,id=2"}
Number Zisterne_Sensor_Stoerung "Stoerung Niveausensor" {bacnet="device=1337,type=binaryInput,id=3"}
//Gartenventile
Number Garten_Wasserventil_Haecke "Bewaesserung Hecke" {bacnet="device=1337,type=binaryOutput,id=1"}
Number Garten_Wasserventil_2 "Bewaesserung Ventil 2" {bacnet="device=1337,type=binaryOutput,id=2"}
//Heizung
////Schlafzimmer
Number Schlafzimmer_Temperatur_Xi_BACnet "Schlafzimmer Temperatur Xi" {bacnet="device=1337,type=AnalogInput,id=1"}
////Buero
Number Buero_Temperatur_Xi_BACnet "Buero Temperatur Xi" {bacnet="device=1337,type=AnalogInput,id=2"}
////Wohnzimmer
Number Wohnzimmer_Temperatur_Xi_BACnet "Wohnzimmer Temperatur Xi" {bacnet="device=1337,type=AnalogInput,id=5"}
////Kueche
Number Kueche_Temperatur_Xi_BACnet "Kueche Temperatur Xi" {bacnet="device=1337,type=AnalogInput,id=6"}
////Bad
Number Bad_Temperatur_Xi_BACnet "Bad Temperatur Xi" {bacnet="device=1337,type=AnalogInput,id=7"}
Did this happen recently after an update?
on every change
No I mean after updating openHAB?
No I only restarted the Pi and it’s only by items I use on HABPanel
Put the bacnet binding in debug mode and publish the log, please
08:54:29.884 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:54:31.670 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Fuellstand to value 53.7 through property Property[1337.ANALOG_INPUT.8]
08:54:31.976 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_Haecke to value Active through property Property[1337.BINARY_OUTPUT.1]
08:54:32.290 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:54:34.170 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:54:36.523 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Temperature to value 19.67 through property Property[1337.ANALOG_INPUT.3]
08:54:37.020 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Humidity to value 58.3 through property Property[1337.ANALOG_INPUT.4]
08:54:37.637 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Wasserwerk_Ueberwachung to value Inactive through property Property[1337.BINARY_INPUT.2]
08:54:38.139 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:54:41.467 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Regenmelder to value Inactive through property Property[1337.BINARY_INPUT.1]
08:54:41.907 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Stoerung to value Inactive through property Property[1337.BINARY_INPUT.3]
08:54:42.207 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_2 to value Inactive through property Property[1337.BINARY_OUTPUT.2]
08:54:42.467 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Winkel to value 42.3 through property Property[1337.ANALOG_INPUT.9]
08:54:42.807 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:54:59.815 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:00.471 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Fuellstand to value 53.7 through property Property[1337.ANALOG_INPUT.8]
08:55:00.654 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_Haecke to value Active through property Property[1337.BINARY_OUTPUT.1]
08:55:00.895 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:01.979 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:02.642 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Temperature to value 19.69 through property Property[1337.ANALOG_INPUT.3]
08:55:02.878 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Humidity to value 58.3 through property Property[1337.ANALOG_INPUT.4]
08:55:03.092 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Wasserwerk_Ueberwachung to value Inactive through property Property[1337.BINARY_INPUT.2]
08:55:03.243 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:03.935 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Regenmelder to value Inactive through property Property[1337.BINARY_INPUT.1]
08:55:04.096 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Stoerung to value Inactive through property Property[1337.BINARY_INPUT.3]
08:55:04.270 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_2 to value Inactive through property Property[1337.BINARY_OUTPUT.2]
08:55:04.434 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Winkel to value 42.3 through property Property[1337.ANALOG_INPUT.9]
08:55:04.590 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:29.809 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:30.637 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Fuellstand to value 53.7 through property Property[1337.ANALOG_INPUT.8]
08:55:30.835 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_Haecke to value Active through property Property[1337.BINARY_OUTPUT.1]
08:55:31.021 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:36.571 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:37.348 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Temperature to value 19.72 through property Property[1337.ANALOG_INPUT.3]
08:55:37.648 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Humidity to value 58.3 through property Property[1337.ANALOG_INPUT.4]
08:55:37.893 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Wasserwerk_Ueberwachung to value Inactive through property Property[1337.BINARY_INPUT.2]
08:55:38.076 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:38.808 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Regenmelder to value Inactive through property Property[1337.BINARY_INPUT.1]
08:55:38.980 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Stoerung to value Inactive through property Property[1337.BINARY_INPUT.3]
08:55:39.136 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_2 to value Inactive through property Property[1337.BINARY_OUTPUT.2]
08:55:39.404 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Winkel to value 42.3 through property Property[1337.ANALOG_INPUT.9]
08:55:39.571 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:55:59.809 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:56:01.119 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Fuellstand to value 53.7 through property Property[1337.ANALOG_INPUT.8]
08:56:01.688 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_Haecke to value Active through property Property[1337.BINARY_OUTPUT.1]
08:56:01.921 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:56:02.780 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:56:03.737 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Temperature to value 19.7 through property Property[1337.ANALOG_INPUT.3]
08:56:03.967 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Outside_Humidity to value 58.3 through property Property[1337.ANALOG_INPUT.4]
08:56:04.216 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Wasserwerk_Ueberwachung to value Inactive through property Property[1337.BINARY_INPUT.2]
08:56:04.505 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:56:05.255 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Regenmelder to value Inactive through property Property[1337.BINARY_INPUT.1]
08:56:05.435 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Stoerung to value Inactive through property Property[1337.BINARY_INPUT.3]
08:56:05.635 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Garten_Wasserventil_2 to value Inactive through property Property[1337.BINARY_OUTPUT.2]
08:56:05.799 [DEBUG] [binding.bacnet.internal.BacNetBinding] - Updating item Zisterne_Sensor_Winkel to value 42.3 through property Property[1337.ANALOG_INPUT.9]
08:56:05.980 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
08:56:29.814 [ERROR] [acnet.internal.queue.ReadPropertyTask] - Could not set read property [FAILED toString()]
@splatch
Hi Lukasz, Do you still look after this binding?
Can you help, here?
Hey, thanks for pulling me into topic. I do maintain 1.x integration. From stack trace I can’t clearly say what happens - possibly property identifier is malformed (not an int for some reason) causing in the end null pointer.
I see you are using version from January. I just released 1.12.0. It is the same code as previous release, but to be on safe side please update and then we will track issue.
Hopefully I will be back on openhab related topics in few weeks and will sort most annoying issues for 1.x line.
After an upgrade from OH 2.2 to 2.3 no more errors…
