[SOLVED] Basic&PaperUI Umlauts not showing
My Basic&PaperUI cant show Umlauts. Both Raspi 4 and Openhabian-config are set to de_UTF-8.
If i eg create a new Room in PaperUi like “Küche”, it will show up as Küche until i reboot. After that it will display as K??che.
My BasicUi cant even show them until reboot.
Are there more settings i didnt set right?
edit:typo
Don’t you need DE_de (as opposed to CH_de etc.)?
https://community.openhab.org/t/setting-locale-failed/45217`
I took a quick look in my openhabian-config: Actually it is de_DE.UTF-8 UTF-8.
I changed it to CH and back, but still no Umlauts.
The link you posted is broken. :confused:
Try Setting locale failed
There was a stray ` at the end of rossko57’s posted URL.
Maybe that is another typo?
yep saw that later, sorry
I found the problem: The raspi locales werent installed.
sudo apt-get install locales
Set locals afterwards and done. :slight_smile:
Thx for your help guys
That makes sense. Was there a clue, a loģged complaint about missing locale?
When setting the openhabian-config, there was something like „local language file does not exist“. So i just yolo-installed it.
