I updated my raspberry with 2.5 build 1600
In BasicUI and App. OS, maps with Groups no longer work.
Until build 1594 or 1597
works properly, no problem with the .sitemaps
file
2019-05-26 07:23:45.318 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-26 07:23:45.321 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Termostato_rustico' for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-26 07:23:45.323 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Termostato_rustico' for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-26 07:23:45.326 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-26 07:23:45.331 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'cenplus_tapp_giorno' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.333 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'cenplus_tapp_giorno' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.335 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.338 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'cenplus_tapp_close' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.345 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'cenplus_tapp_close' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.347 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.350 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test9' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.352 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test9' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.354 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.357 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test10' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.359 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test10' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.362 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.365 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test11' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.367 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test11' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.369 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.372 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test12' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.374 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cenplus_test12' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.376 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.379 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cen_test9' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.381 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cen_test9' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.383 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.386 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cen_test10' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.388 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'iLR_cen_test10' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-05-26 07:23:45.390 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
Frame label="Casa" {
Group item=P_PianoTerreno label="Piano Terreno" icon="groundfloor"
Group item=P_Seminterrato label="Piano Seminterrato" icon="cellar"
Group item=C_Esterno label="Esterno" icon="garden"
Group P_PianoTerreno "Piano Terreno" <groundfloor> ["GroundFloor"]
Group P_Seminterrato "Rustico" <cellar> ["Basement"]
Group P_Esterno "Garden" <garden> ["Garden"]
Group P_Generale "Generale" ["Generale"]
Group C_Allarme "Allarme" <corridor> ["alarm"]
Group G_Scenari "Scenari" <corridor> ["alarm"]
Group:Switch:OR(ON, OFF) G_Lights "Luci" <light> (P_Generale) ["Luci [(%d)]"]
/* Locale */
Group C_Sala "Sala" <sofa> (P_PianoTerreno) ["kitchen"]
Switch Luce_sala "Sala" <light> (C_Sala, G_Lights) [ "Lighting" ] { channel="openwebnet:bus_on_off_switch:mybridge:mylig_sala:switch" }
Group P_PianoTerreno Works well
Group C_Sala Not works
