Probably unrelated to the Blacklist issues, but so far on brand new test setup.
No issues installing Zulu and OH2. Few stops/starts. and restarts no errors.
Install the NTP binding, again no issues.
Installed the Hue Binding, and then see these warnings in the logs.
Probably not related, but thought would report. I have been getting Blacklist issues about 6:30am each day, so will leave this test machine as is for now and see what it shows tomorrow morning.
2017-12-07 13:37:12.935 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-12-07 13:37:29.603 [WARN ] [nal.common.AbstractInvocationHandler] - Timeout of 5000ms exceeded while calling method 'ThingHandler.initialize()' on 'org.eclipse.smarthome.binding.hue.handler.HueLightHandler@25f0ef18'. Thread 'safeCall-7' (181) is in state 'WAITING'
at sun.misc.Unsafe.park(Native Method)
at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.parkAndCheckInterrupt(AbstractQueuedSynchronizer.java:836)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.acquireQueued(AbstractQueuedSynchronizer.java:870)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.acquire(AbstractQueuedSynchronizer.java:1199)
at java.util.concurrent.locks.ReentrantLock$NonfairSync.lock(ReentrantLock.java:209)
at java.util.concurrent.locks.ReentrantLock.lock(ReentrantLock.java:285)
at org.eclipse.smarthome.core.thing.internal.ThingManager.thingUpdated(ThingManager.java:406)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:222)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:145)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:1)
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:188)
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:62)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:86)
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.update(AbstractManagedProvider.java:132)
at org.eclipse.smarthome.core.thing.internal.ThingManager$1$1.run(ThingManager.java:233)
at org.eclipse.smarthome.core.thing.internal.ThingManager$1$1.run(ThingManager.java:1)
at java.security.AccessController.doPrivileged(Native Method)
2017-12-07 13:37:29.605 [WARN ] [ome.core.thing.internal.ThingManager] - Initializing handler for thing 'hue:0210:00178824e7e9:1' takes more than 5000ms.
