Have a basic issue: how do you make the MQTT Broadlink Bridge recognize your Broadlink device? Is there a place where i should enter the device IP or MAC? Thx
thatās a great question !
I checked the docs: broadlink-mqtt-bridge/README.md at master Ā· fbacker/broadlink-mqtt-bridge Ā· GitHub and it is not clear to me either
I assume that after you install the bridge, you will need to use the admin interface (at port 3000) to set your Broadlink devices (not sureā¦ I donāt use this solution since I donāt have a Broadlink). It seems that the bridge discovers them on the LAN.
edit: check How to select a broadlink device Ā· Issue #1 Ā· fbacker/broadlink-mqtt-bridge Ā· GitHub
