rule "Flur Licht morgens"
Item itmFIBmotion2 changed to 1
hueFlur_Color.sendCommand("360,80,30")
I just made the upgrade from oH 2.3.0 to 2.4.0 and now i´m not able to control my hue bulbs anymore.
The rule above worked with 2.3.0 but now throws an error that "360,80,30" cannot be converted to a command type.
2019-01-03 23:54:42.320 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert '360,80,30' to a command type which item 'hueFlur_Color' accepts: [HSBType, PercentType, OnOffType, IncreaseDecreaseType, RefreshType].
I had a look at the changlog of 2.4.0 but it only says: Enhancements 5946 Added support for bulbs using CIE XY colormode only 6511 Added support for sensors Bug Fixes 6629 Fixed brightness of 1 shown as OFF
How do i control my hue bulbs with 2.4.0?
And where do i get the .jar files for 2.3.0 bindings…?
Looks like there´s a bug in the binding.
When changing the bulb with the hue app a error is shown in the logs
2019-01-04 00:14:18.300 [ERROR] [ue.internal.handler.HueBridgeHandler] - An exception occurred while calling the BridgeHeartbeatListener
java.lang.IllegalArgumentException: Hue must be between 0 and 360
at org.eclipse.smarthome.core.library.types.HSBType.validateValue(HSBType.java:106) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.library.types.HSBType.<init>(HSBType.java:81) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.binding.hue.internal.handler.LightStateConverter.fromHSBtoHSBType(LightStateConverter.java:234) ~[268:org.eclipse.smarthome.binding.hue:0.10.0.oh240]
at org.eclipse.smarthome.binding.hue.internal.handler.LightStateConverter.toHSBType(LightStateConverter.java:222) ~[268:org.eclipse.smarthome.binding.hue:0.10.0.oh240]
at org.eclipse.smarthome.binding.hue.internal.handler.HueLightHandler.onLightStateChanged(HueLightHandler.java:414) ~[268:org.eclipse.smarthome.binding.hue:0.10.0.oh240]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler.notifyLightStatusListeners(HueBridgeHandler.java:651) [268:org.eclipse.smarthome.binding.hue:0.10.0.oh240]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler.access$7(HueBridgeHandler.java:636) [268:org.eclipse.smarthome.binding.hue:0.10.0.oh240]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler$2.doConnectedRun(HueBridgeHandler.java:238) [268:org.eclipse.smarthome.binding.hue:0.10.0.oh240]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler$PollingRunnable.run(HueBridgeHandler.java:101) [268:org.eclipse.smarthome.binding.hue:0.10.0.oh240]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Ok got it!
The binding thinks that 360 is not allowed for the H(ue) in HSB.
But the error says the value has to be between 0 and 360…
Actually, this is still happening (or again) in 2.5.12. I don’t expect anyone will fix that old version, but maybe someone can use this information when searching for the error message.
