[SOLVED] Build Error
Select your project, right click, and select Update Maven Project. I don’t know exactly what it is doing, but it is one of the things that I pull out of my toolbox that has helped to fix things in the IDE.
Where is the code?
BTW, code fences make logs and code much easier to read. It looks like you used quotes in the OP.
