Hi everyone!
I have been using the binding, but now I only get this error:
2018-10-10 18:42:38.897 [ERROR] [org.quartz.core.ErrorLogger ] - Job (event-reloader.google threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [106:org.eclipse.smarthome.core.scheduler:0.10.0.oh240M4]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [106:org.eclipse.smarthome.core.scheduler:0.10.0.oh240M4]
Caused by: java.util.ServiceConfigurationError: net.fortuna.ical4j.model.PropertyFactory: Provider net.fortuna.ical4j.model.property.Action$Factory not a subtype
at java.util.ServiceLoader.fail(ServiceLoader.java:239) ~[?:?]
at java.util.ServiceLoader.access$300(ServiceLoader.java:185) ~[?:?]
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:376) ~[?:?]
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404) ~[?:?]
at java.util.ServiceLoader$1.next(ServiceLoader.java:480) ~[?:?]
at net.fortuna.ical4j.model.AbstractContentFactory.getFactory(AbstractContentFactory.java:85) ~[?:?]
at net.fortuna.ical4j.model.PropertyFactoryImpl.createProperty(PropertyFactoryImpl.java:78) ~[?:?]
at net.fortuna.ical4j.data.CalendarBuilder$ContentHandlerImpl.startProperty(CalendarBuilder.java:326) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.parse(CalendarParserImpl.java:206) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.access$1100(CalendarParserImpl.java:190) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:173) ~[?:?]
at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:122) ~[?:?]
at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:198) ~[?:?]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:339) ~[?:?]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:320) ~[?:?]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:137) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
Also, I don’t know how I could delete my old calendars which don’t work now. I have deleted from the .cfg file, but I can still see that reload job scheduled for ‘old calendar’ and I also get these exceptions for them too.
