I have 2 following rules in 2 different files: lighting.rules:
rule "Entrace Door Opened"
Item Entrace_Door_Sensor received update OPEN
logInfo("lighting.rules","Door Sensor = " + Entrace_Door_Sensor.state.toString)
if ((Color_Bulb.state == 0) && (Openhab_Theme.state < NA_WAKACJACH)) {
Color_Bulb_Artificial.postUpdate(ON)
Color_Bulb.sendCommand(1)
theme.rules:
logInfo("theme.rules","Door Sensor = " + Entrace_Door_Sensor.state.toString)
if (Openhab_Theme.state == POZA_DOMEM) { updateTheme.apply(now) }
Though only the theme.rules seem to work:
2019-12-09 19:09:02.054 [INFO ] [e.smarthome.model.script.theme.rules] - Door Sensor = OPEN
2019-12-09 19:09:02.062 [vent.ItemStateChangedEvent] - Entrace_Door_Sensor changed from CLOSED to OPEN
2019-12-09 19:09:02.072 [vent.ItemStateChangedEvent] - Last_Activity changed from 2019-12-09T19:08:38.132+0100 to 2019-12-09T19:09:02.040+0100
2019-12-09 19:09:02.083 [ome.event.ItemCommandEvent] - Item 'Openhab_Theme' received command 1
2019-12-09 19:09:02.105 [vent.ItemStateChangedEvent] - Openhab_Theme changed from 8 to 1
2019-12-09 19:09:02.139 [vent.ItemStateChangedEvent] - Openhab_Last_Theme changed from 8 to 1
There are other rules in lighting.rules, that work perfectly fine. Can I trigger 2 different rules with the same Item event?
To sumarise:
Same event can trigger different rules, but make shure, that rule names are different.
BTW, I found a bug here. The result of “if (Openhab_Theme.state == POZA_DOMEM)” can be different depending on, which rule will be calculated first, because the “updateTheme.apply(now)” changes the Openhab_Theme state.
Yes, it’s possible, but I would not recommend it. Triggering two rules at exactly the same time can cause high load and slower execution than if you had a single rule. Just combine the bodies of both rules into one.
@5iver: Can you extrapolate a little bit about the high load and slower execution? I’m curious to know “how much load / additional execution”? Generally speaking, load / execution time are not primary considerations of mine, but maintaining code “readability” is.
In terms of the problem I’m trying to solve, I’m trying to write quite a bit of automation around maintaining room temperatures for each bedroom in my house. Each bedroom has a smart vent, a ceiling fan, a door sensor, a temperature sensor, occupancy sensor, window sensor, etc. Some bedrooms have different combinations of sensors. There is a single (ecobee3) thermostat that controls all of the rooms.
I believe (and I’ve just started) that from a “code maintenance” perspective, it will be considerably easier to write a rule (rule file) for each room, taking in all of the logic and sensors available in that room. However, each room would need to use the thermostat status change as a trigger to execute the room rules, and so, a thermostat change would trigger at least 3-5 simultaneous rules.
For perspective, I’m willing to take slight (20%-50%?) load and execution time increases in order to have easier to maintain code. I’m running openhab as a VM on a 2x Xeon x5650 w/ 128GB RAM, so I think I have plenty of horsepower to spare.
It’s an old post.
If you are running OH3, you’re probably using a different rule engine to the original discussion, which manages multiple rule threads differently.
I’m on your side - this is home automation, not real time flight control. A response time of seconds for thermostat functions is no problem.
Human response time to e.g. button triggered lighting delays is generally the ruling “annoyance” factor More than 200mS starts getting noticeable.
Your available horsepower should make this a non-issue. From experience, higher power boxes generally expose different concurrency issues in rules that pass Pi users by.
Reminder that rule performance is affected by other system factors - “persisting everything” is easy to do but has a cost, for an example.
