Hi
I need to change the password in the Netatmo binding on the Netatmo API thing.
However, I get an “409 Conflict” error when I try to do that.
I tried to delete the thing, but that gives the same error.
Pleas help, as I am lost right now
Hi
This generally means that you have defined the thing in a text file and not through the UI and it must therefore be edited in the text file, and not the UI…
right you are! Thank you
