[solved] Can't get any page from basicUI with 4.2 release
related to this:
evey click on sitemap is now with OH 4.2 resulting in this error:
2024-07-08 10:24:20.972 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /basicui/app
java.lang.NoSuchMethodError: 'void org.openhab.core.io.rest.sitemap.SitemapSubscriptionService.setPageId(java.lang.String, java.lang.String, java.lang.String)'        at org.openhab.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:175) ~[?:?]
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:584) ~[bundleFile:4.0.4]
        at org.ops4j.pax.web.service.spi.servlet.OsgiInitializedServlet.service(OsgiInitializedServlet.java:102) ~[?:?]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[?:?]
        at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1656) ~[?:?]
        at org.ops4j.pax.web.service.spi.servlet.OsgiFilterChain.doFilter(OsgiFilterChain.java:113) ~[?:?]
        at org.ops4j.pax.web.service.jetty.internal.PaxWebServletHandler.doHandle(PaxWebServletHandler.java:334) ~[?:?]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[?:?]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505) ~[?:?]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:234) ~[bundleFile:9.4.54.v20240208]
        at org.ops4j.pax.web.service.jetty.internal.PrioritizedHandlerCollection.handle(PrioritizedHandlerCollection.java:96) ~[?:?]
        at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:731) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) ~[bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.54.v20240208]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.54.v20240208]
2024-07-08 10:24:29.636 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /basicui/app
any solution? till OH 4.2 my sitemap was completely fine and working, not really sure where to look for the error??
I can’t reproduce this with 4.2.0.RC1, and none of the changes from RC1 to RC2 should case this.
I will upgrade to 4.2.0 release build later and check again.
Do you have Basic UI manually installed (i.e. dropped a JAR into the addons folder??
yes If I recon correctly, shall I redo it?
when I try to stop OH in logs I do have this:
2024-07-08 10:49:50.489 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2024-07-08 10:49:55.741 [WARN ] [org.eclipse.jetty.io.ManagedSelector] - java.nio.channels.ClosedSelectorException
2024-07-08 10:50:01.769 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://home.mak.xx/rest/sitemaps/events/subscribe's Observer
2024-07-08 10:50:11.764 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://home.mak.xx/rest/sitemaps/events/subscribe's Observer
2024-07-08 10:50:21.760 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://home.mak.xx/rest/sitemaps/events/subscribe's Observer
2024-07-08 10:50:31.758 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://home.mak.xx/rest/sitemaps/events/subscribe's Observer
2024-07-08 10:50:56.750 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://home.mak.xx/rest/sitemaps/events/subscribe's Observer
That is the problem … there were changes to openHAB core and your Basic UI JAR is not compatible any more.
Please remove the JAR and install Basic UI from the add-on store in Main UI.
ok will do, thanks
In general: If you drop JARs into the add-on folder, expect issues when upgrading openHAB and don’t blame openHAB, because the JAR obviously won’t automatically upgrade with openHAB - that is something the user has to take care of.
Fortunately you normally don’t need to drop JARs into that folder.
removed jar, started OH, but OH still sees it as installed, can’t uninstall.
found this bug, but it’s closed and for OH2
do i need to look into more folders somewhere? (debian)
In that case I would try it with remove the JAR while openHAB is running, and if it’s still shown as installed stop openHAB and clean cache.
ok clean-cache worked
now i need to figure out where dark mode and icons dissapeared from “new” basicUI :face_holding_back_tears:
I opened a PR to have OH automatically address this as part of the upgrade process but there was a lot of pushback. I’m open to ideas.
It should at least warn somewhere that you have incompatible something somewhere, no need to do automatic update/or so, but for example in my case I was not aware that it might be an issue at all → as all previous updates has been working without any issues.
log full of errors and non working UI and this community helps every time, but admin UI shall be notifining users as well.
My original suggestion on that issue was to rename or move the .jar files or .kar files somewhere out of the way with warnings in the logs. The reason for that was that at the time (and maybe still now?) there can be cases where uncompatible jar/kar files in the add-ons folder can prevent OH from even starting. But apparently those who don’t suffer this problem don’t care about those who do so I’ll just add a warning to the update scripts. Sadly, few actually read those logs so :person_shrugging: .
