I did the inclusion process of my zwave devices in openzwave (everything went fine in only 10 minutes).
Afterwards I started openhab 1.7.1
Result: Node3 has a grey icon in habmin
Next step was to wake up SF812 manually (close to the ZWave Controller).
See the result in screenshot below:
It is very interessting for me, that I receive an event after pushin the TAMPER Button, but on the end of the message is “Transaction not complete: node address inconsistent”
What steps has to be done, for a correct Transaction ?
Take a look here and also read these links in one of my posts.
Edit: Sorry, didn’t follow your links … you already found that post
Second Edit: I also tried to make the SF812 work with openzwave: no success either. At Xmas I hopefully get a new smoke sensor and then I will kick that Everspring down the hallway …
I steped back to openhab 1.6.2 with org.openhab.binding-zwave.1.6.2.jar and everything works fine.
I think there is a bug in 1.7.1.
If you need some information, I can send you the logs.
[quote=“wl12, post:4, topic:5175, full:true”]
did you solve your problem ?[/quote]
No, the device still shows gray in habmin, doesn’t report tamper and battery, but the smoke alarm gives me a open/closed in OH when the test button is pushed.
I’m on a slightly older 1.8 snapshot (1.8.0.201511090246), same issue.
Do you have any indication that it should work with the newest snapshot?
Then I may try it …
This is normal - it’s a debug message, not an error.
Please ensure that you wake the device up a couple of times at least, while it is close to the controller to allow the binding to initialise the device for the first time…
If it’s still not working, please provide a logfile and I will take a look.
