Hello Guys.
Trying to install some bindings on a freshly installed openhabian from the PaperUI…
When trying to install, the “thinking circle” just keeps rotating, and nothing happens - no bindings is installed…
Checking the log and it says_:
Install on Raspberry Pi or other? With the limited info above I would stop OH and reboot, see if that helps.
Sorry no, installed on a fresh Ubuntu 19.10 machine…
Note, seemed to work when in the openhabian config i ran the option to set correct permissions for all - and then rebootet…
Good deal!
where did you change the permissions?
A option inside the openhabian-config
