I have openhab2 with miio binding. I try to make a rule to switch on and off a ceiling light with a wireles switch. Ithink the rule is ok, but in the log i get these warnings and nothing happening when i press the switch.
Any idea what to do?
.items:
Switch LR_CL_Power "Power" {channel="miio:basic:ea28b6db:power"}
.rule:
rule "LR_SW_2"
Channel "mihome:86sw2:7811dcb24692:158d000255eab4:ch2" triggered SHORT_PRESSED
if (LR_CL_Power.state == OFF || LR_CL_Power.state == NULL){
LR_CL_Power.sendCommand(ON)
else{
LR_CL_Power.sendCommand(OFF)
Log:
2019-04-21 08:49:26.556 [vent.ChannelTriggeredEvent] - mihome:86sw2:7811dcb24692:158d000255eab4:ch2 triggered SHORT_PRESSED
2019-04-21 08:49:26.604 [ome.event.ItemCommandEvent] - Item 'LR_CL_Power' received command OFF
2019-04-21 08:49:26.616 [nt.ItemStatePredictedEvent] - LR_CL_Power predicted to become OFF
2019-04-21 08:49:26.625 [vent.ItemStateChangedEvent] - LR_CL_Power changed from ON to OFF
2019-04-21 08:59:10.181 [vent.ChannelTriggeredEvent] - mihome:86sw2:7811dcb24692:158d000255eab4:ch2 triggered SHORT_PRESSED
2019-04-21 08:59:10.233 [ome.event.ItemCommandEvent] - Item 'LR_CL_Power' received command ON
2019-04-21 08:59:10.245 [nt.ItemStatePredictedEvent] - LR_CL_Power predicted to become ON
2019-04-21 08:59:10.256 [vent.ItemStateChangedEvent] - LR_CL_Power changed from OFF to ON
2019-04-21 08:59:10.321 [WARN ] [nal.transport.MiIoAsyncCommunication] - Error while polling/sending message
java.nio.BufferOverflowException: null
at java.nio.HeapByteBuffer.put(HeapByteBuffer.java:189) ~[?:?]
at java.nio.ByteBuffer.put(ByteBuffer.java:859) ~[?:?]
at org.openhab.binding.miio.internal.Message.createMsgData(Message.java:63) ~[219:org.openhab.binding.miio:2.4.0]
at org.openhab.binding.miio.internal.transport.MiIoAsyncCommunication.sendCommand(MiIoAsyncCommunication.java:246) ~[219:org.openhab.binding.miio:2.4.0]
at org.openhab.binding.miio.internal.transport.MiIoAsyncCommunication.sendMiIoSendCommand(MiIoAsyncCommunication.java:161) ~[219:org.openhab.binding.miio:2.4.0]
at org.openhab.binding.miio.internal.transport.MiIoAsyncCommunication$MessageSenderThread.run(MiIoAsyncCommunication.java:219) [219:org.openhab.binding.miio:2.4.0]
