I’m trying to use temp sensors connected on a ESP12 flashed with espeasy.
At the moment i have 2 sensors connected witch are working fine and are publishing there data.
The problem witch i have is that i have a file created with the 2 sensors but only 1 is showing up in PaperUI.
When i link the one that showed up with the 2 items i always get the same value.
What am i doing wrong?
Thing mqtt:topic:Esp1 "Huis" (mqtt:systemBroker:embedded-mqtt-broker) @ "Huis" {
Channels:
Type number : temp "T_Aan" [ stateTopic="ESP1/Aanvoer/A1" ]
Type number : temp "T_Af" [ stateTopic="ESP1/Afvoer/A2" ]
Number GF_LR_Aanvoer "T_Aan [%.1f °C]" <temperature> (Home, gTemperature) { channel="mqtt:systemBroker:embedded-mqtt-broker:ESP1:Aanvoer:A1" }
Number GF_LR_Afvoer "T_Af [%.1f °C]" <temperature> (Home, gTemperature) { channel="mqtt:systemBroker:embedded-mqtt-broker:ESP1:Afvoer:A2" }
