c_nagel
(Christoph Nagel)
January 3, 2018, 10:13am
1
just a short question of a OH-beginner (Raspi 3B, OH2, Z-Wave):
How can I check if my defined items of the *.items-file are accepted by OH2?
I have created a nice Sitemap which is shown properly i.e. by the iOS-App, but it obviously does not access my items.
Defining items and channels via PaperUI is working fine.
Any ideas/ suggestions? Thanks a lot in advance!
Christoph
hr3
(Harry)
January 3, 2018, 10:25am
2
Are the items shown in paper-ui?
What do you mean with “does not access”?
Are there entrys in the log?
c_nagel
(Christoph Nagel)
January 3, 2018, 11:32am
3
No, the items from my items file are not shown in Paper UI. Only the items I defined in Paper UI are shown.
“Does not access”: For instance temperature and luminance values from the sensor are not shown, though it’s working with the items I defined in Paper UI; the same to the Power Switch.
Where do I find the log?
opus
(JĂĽrgen Baginski)
January 3, 2018, 11:38am
4
Did you consider to look into the documentation (https://docs.openhab.org )?
c_nagel
(Christoph Nagel)
January 3, 2018, 11:41am
5
Yes, I spent hours of reading in the documentation, manuals, and tutorials …
hr3
(Harry)
January 3, 2018, 11:50am
6
Log Files in openHABian
Which editor do you use?
Show your item- and sitemap-definition and we can help.
c_nagel
(Christoph Nagel)
January 3, 2018, 11:53am
7
I use nano.
Cool, I’ll show you the content of the items- and the sitemap-file later when I’m back home.
hr3
(Harry)
January 3, 2018, 11:55am
8
c_nagel
(Christoph Nagel)
January 3, 2018, 12:04pm
9
Which editor would you recommend?
I’m using a Mac for configuration my Raspi 3B with Openhabian via SSH-connection.
Confused
(Garry Mitchell)
January 3, 2018, 12:15pm
10
Items created in .items files will not display in the Control section of PaperUI.
They should, however, still show in PaperUI under Configuration -> Items (although you won’t be able to see current values, or change them).
The correct way to interact with these items is via BasicUI/app (using a .sitemap file) or via something like HABpanel.
hr3
(Harry)
January 3, 2018, 12:16pm
11
I use VSCode. It isn’t perfect, but has the best integration.
opus
(JĂĽrgen Baginski)
January 3, 2018, 2:28pm
12
You have to note that Items are only shown on PaperUI if the Simple Mode (for item creating)is OFF!
c_nagel
(Christoph Nagel)
January 4, 2018, 5:39am
13
Good morning,
the items-file:
//Items
DateTime Datum "Heute ist [%1$ta %1$tR]" <time>
Number Temp_EZ_soll "Temperatur Esszimmer [%.1f °C]" <temperature> (gHeizung) ["Heizungen"] {channel="zwave:device:78e36f13:node6:thermostat_setpoint_heating"}
DateTime Temp_EZ_Update "Letzte Einstellung [%1$ta %1$tR]" <time> (gUpdates) ["Updates"]
Number Temp_EZ_Batt "Batterieladung [%d %%]" <batterylevel> (gBatterien) ["Batterien"] {channel="zwave:device:78e36f13:node6:battery-level"}
Number Temp_Bad_soll "Temperatur Bad [%.1f °C]" <temperature> (gHeizung) ["Heizungen"] {channel="zwave:device:78e36f13:node17:thermostat_setpoint_heating"}
DateTime Temp_Bad_Update "Letzte Einstellung [%1$ta %1$tR]" <time> (gUpdates) ["Updates"]
Number Temp_Bad_Batt "Batterieladung [%d %%]" <batterylevel> (gBatterien) ["Batterien"] {channel="zwave:device:78e36f13:node17:battery-level"}
Switch Licht_EZ "Licht Esszimmer" <light> (gLicht) ["Licht"] {channel="zwave:device:78e36f13:node9:switch_binary"}
Number Licht_Verbr_akt "Akt. Verbrauch" <energy> (gEnergie) ["Energie"] {channel="zwave:device:78e36f13:node9:meter_wat$}
Number Licht_Verbr_ges "Ges.-Verbrauch" <line> (gEnergie) ["Energie"] {channel="zwave:device:78e36f13:node9:meter_kwh"}
The sitemap-file:
//Sitemap
sitemap MCC label="MCC Home" icon="smiley"
Frame label="Datum" icon="time"
Text item=Datum
Frame label="Heizungen" icon="heating"
Setpoint item=Temp_EZ_soll label="Esszimmer [%.1f °C]" icon="heating" minValue=4 maxValue=28 step=1.0
Switch item=Temp_EZ_select label="Voreinst." icon="temperature" mappings=[0="Tag", 1="Nacht"]
Setpoint item=Temp_Bad_soll label="Bad [%.1f °C]" icon="heating" minValue=4 maxValue=28 step=1.0
Switch item=Temp_Bad_select label="Voreinst." icon="temperature" mappings=[0="Tag", 1="Nacht", 2="Baden"]
Setpoint item=Temp_WZ_soll label="Wohnzimmer [%.1f °C]" icon="heating" minValue=4 maxValue=28 step=1.0
Switch item=Temp_WZ_select label="Voreinst." icon="temperature" mappings=[0="Tag", 1="Nacht"]
Frame label="Licht"
Switch item=Licht_EZ label="Licht" icon="light"
Text item=Licht_Verbr_akt label="Akt. Verbrauch [%.1f W]" icon="energy"
Text item=Licht_Verbr_ges label="Ges.-Verbrauch [%.1f kWh]" icon="line"
Frame label="Sensor Esszimmer"
Text item=Temperatur_EZ label="Temperatur [%.1f °C]" icon="temperature"
Text item=Luminanz_EZ label="Helligkeit [%.1f lm]" icon="sun_clouds"
The items named *_Update and *_Batt are not important at the moment and I wanted to use and implement them later on step by step.
Thanks!
hr3
(Harry)
January 4, 2018, 7:30am
14
Number Licht_Verbr_akt "Akt. Verbrauch" <energy> (gEnergie) ["Energie"] {channel="zwave:device:78e36f13:node9:meter_wat"}
c_nagel
(Christoph Nagel)
January 4, 2018, 10:52am
15
c_nagel
(Christoph Nagel)
January 6, 2018, 3:13pm
16
@hr3 Hi, may I ask you for a little help configuring Visual Studio Code?
I have a Mac using Mac OS X High Sierra.
Openhab is running on a Raspi 3B.
After opening the preferences I entered
“openhab.host”: “xberry”,
“openhab.port”: 8080
But all I get in the explorer window are the folders:
-lost + found
-root
without any subfolders.
What did I do wrong?
hr3
(Harry)
January 6, 2018, 3:47pm
17
I use Samba network share.
