All items are updated and have valid values. This was checked using an extra sitemap for testing.
Now I’d like to set up a rule that checks if tDate1 is set for today or maybe tomorrow.
So effectively I’d like to display all dates scheduled for today in the sitemap and all dates due tomorrow in another frame of that sitemap.
Also, a passed date should still be displayed (e.g. an appointment scheduled for 9:00 today should still be displayed in the evening) just like in a real calender made from paper.
There are quite a few examples but I didn’t get any of them to work as they seem to check the time now instead of today’s date. This also has the effect that today’s dates are deleted from the list because they are elapsed.
Also different approaches are used like isAfter, isBefore
or (time1 > time2)
which is quite confusing and hard to get to run at all.
So how do I check if the items above tDate1 and tDate2
are scheduled for today / tomorrow and keep them in the sitemap all day?
I’ll be happy to try out your suggestions. Maybe there’s even a working example.
Please specify the required include files as in the past it took me a lot of time to figure out what needs to be included.
CalDAV does not return past events. If those should be displayed some sort of persistence is required.
For now I’m not gonna implement this. So only current and future events will be shown.
The start and end time of a day can be determined by using withTimeAtStartOfDay.
The start time of an event that’s scheduled for today must be within those boundaries.
With this I came up with the following rules which seem to work alright:
rule "buildDate1"
Item sNameDate1 received update or
Item tTimeDate1 received update
if ((sNameDate1.state != Undefined) && (sNameDate1.state != Uninitialized) &&
(tTimeDate1.state != Undefined) && (tTimeDate1.state != Uninitialized)) {
sNameTimeDate1.postUpdate(sNameDate1.state.format("%1$tH:%1$tM") + " - " + tTimeDate1.state.toString)
The next rule checks if the event is scheduled for today:
rule "todayDate1"
Item tDateToday received update or
if((tTimeDate1.state != Undefined) && (tTimeDate1.state != Uninitialized) &&
now.withTimeAtStartOfDay.isBefore((tTimeDate1.state as DateTimeType).calendar.timeInMillis) &&
now.withTimeAtStartOfDay.plusHours(24).isAfter((tTimeDate1.state as DateTimeType).calendar.timeInMillis) )
sTodayDate1.postUpdate(sNameDate1.state.toString)
