Issue of the topic: Conditional format based on item value
Would like to expose in Sitemap one of two prhase (“Present”, “Not Present”) depending from the item status value (ON or OFF)
I have the following in
Item:
Switch Elenio_C6 “Samsung A5 / Elenio” { channel=“network:pingdevice:elenio_cell:online” }
Sitemap:
Text item=Elenio_C6 label=“Elenio è [%s]” icon=“network”
Didn’t find any Transformation rule for this
How To?
Glad to hear you’ve solved the problem and understand a bit more about MAP.
If you would, please mark the post solved by clicking the square box on the post that provided the solution and edit the title to start with [Solved]. This will help other with a similar issue find a quick solution.
