Totaly new to this so please forgive me. I would like to create a rule that;
When a light is turned on, turn it off after 10 minutes, but only if a second light is off
The idea is, if I go into a room and turn the first light on only its means its a quick visit. But if the second light is turned on within the countdown time, don’t turn the first light off.
From reading other threads I have this but I don’t know the correct syntax.
var Timer Light_Timer = null
val Integer Light_TimeOut = 10
rule “Turn Den Light 4 OFF After 10”
Item DL4_Switch changed from OFF to ON
Light_Timer = createTimer(now.plusMinutes(Light_TimeOut))
{ if (DL1_Switch.state == OFF)
DL4_Switch.sendCommand(OFF)
Light_Timer = null
I’m pretty much a hack, but your code looks reasonable. I test rules like that by using a simple sitemap for my Openhab phone app. That way, I can sit in my recliner and test away. (would also change the timeout to 1 minute during debugging)
When a light is turned on, set the associated expired timer to ON. When the timer expires, check to see if the other light is on, and turn off this light if the other light is off. You can also immediately set the timer to OFF when the second light is turned on.
I am new to OpenHab as well. Here is my current rules for the lights. It’s work in progress but hopefully you can pick out a thing or two out of the code.
Also, you should consider adding a motion sensor so you don’t have to turn on the light manually.
Thank you for your help, The below timer rule works just fine as it currently turns the light back off after 1 minute. But I need to add a condition not to turn off the light if a second light has an ON state after the timer period. Cheers
rule “Turn Den Light 4 OFF”
Light_Timer = null
Hi yfaway, your rules look amazing. Unfortunately I don’t know any code stuff so its all guess work for me. Would you mind having a look at my timer code below and if you have time rewrite to perform the function I need.
Cheers
A small change to the syntax got it working. Thanks yfaway for the ideas in your code. I just needed to put the condition in the timer bit not after it.
if(DL1_Switch.state == OFF)
Light_Timer = null
