I am wondering whether the following page is still valid for Openhab 2.5? [https://www.openhab.org/v2.5/docs/developer/osgi/configadmin.html#using-the-configuration-admin-to-update-the-configuration](http://Using the Configuration Admin to update the configuration)
I have been trying this method but the returned properties/config are empty BUT i am 100% sure it is there because @Modified directive does send me valid config information after i saved the config through PaperUI. I need to use this method because i want to make some changes to the configuration programmatically. Thanks
