I am controlling the watering of my garden from Openhab running on my raspi with a relais board attached to the raspi GPIO pins.
Controlling each of the valves from my basic UI works fine with each walve being resembled as a switch in the sitemap.
Now, for safety reasons I tried to add a watchdog rule that turns off all valves after a maximum active time, just in case I forgot to turn them off again in the UI
Rule:
val topf_timeout=1
rule "Watchdog für Blumentöpfe"
Item valve2Switch received command ON
logInfo("watering.rules", "In rule Blumentopf")
createTimer(now.plusMinutes(topf_timeout)) [| valve2Switch.sendCommand(OFF) ]
What happens is that I see the delayed watchdog event is triggered after one minute (event.log) but the underlying python script is never being called and therefore the valve never turned off
event.log
2018-08-10 15:41:01.717 [ome.event.ItemCommandEvent] - Item 'valve2Switch' received command ON
2018-08-10 15:41:01.733 [vent.ItemStateChangedEvent] - valve2Switch changed from OFF to ON
2018-08-10 15:42:01.782 [ome.event.ItemCommandEvent] - Item 'valve2Switch' received command OFF
openhab2.log
2018-08-10 15:38:53.955 [INFO ] [marthome.model.script.watering.rules] - In rule Blumentopf
2018-08-10 15:41:01.762 [INFO ] [marthome.model.script.watering.rules] - In rule Blumentopf
The first two lines in the event log (15:41:01) are triggered by switching the valve on in the UI
The third line then must be the result of my watchdog rule (here set to 1 minute)
However, this second event never leads to the python script being called. The relais log only shows the call triggered by the UI, not the one from the rule
Maybe I still have some misunderstanding on how the things, items and events work together. Any debug hint would be appreciated.
myhome.sitemap
sitemap myhome label="Thomas Home and Castle" {
Switch item=valve1Switch label="Hauptventil" icon="faucet" //mappings=[ "ON"="ON", "OFF"="OFF" ]
Switch item=valve2Switch label="Blumentöpfe" icon="faucet" //mappings=[ "ON"="ON", "OFF"="OFF" ]
Switch item=valve3Switch label="Blumenbeet" icon="faucet" //mappings=[ "ON"="ON", "OFF"="OFF" ]
Switch item=valve4Switch label="Gemüsebeet" icon="faucet" //mappings=[ "ON"="ON", "OFF"="OFF" ]
valves.items
String valve1Switch "Ventil 1" <switch> [ "Switchable" ] { channel="exec:command:valve1-control:input", autoupdate="true" }
String valve2Switch "Ventil 2" <switch> [ "Switchable" ] { channel="exec:command:valve2-control:input", autoupdate="true" }
String valve3Switch "Ventil 3" <switch> [ "Switchable" ] { channel="exec:command:valve3-control:input", autoupdate="true" }
String valve4Switch "Ventil 4" <switch> [ "Switchable" ] { channel="exec:command:valve4-control:input", autoupdate="true" }
String valve5Switch "Ventil 5" <switch> [ "Switchable" ] { channel="exec:command:valve5-control:input", autoupdate="true" }
String valve6Switch "Ventil 6" <switch> [ "Switchable" ] { channel="exec:command:valve6-control:input", autoupdate="true" }
String valve7Switch "Ventil 7" <switch> [ "Switchable" ] { channel="exec:command:valve7-control:input", autoupdate="true" }
valves.things
Thing exec:command:valve1-control [ command="sudo /etc/openhab2/scripts/relais.py 9 %2$s", interval=0, autorun=true ]
Thing exec:command:valve2-control [ command="sudo /etc/openhab2/scripts/relais.py 10 %2$s", interval=0, autorun=true ]
Thing exec:command:valve3-control [ command="sudo /etc/openhab2/scripts/relais.py 22 %2$s", interval=0, autorun=true ]
Thing exec:command:valve4-control [ command="sudo /etc/openhab2/scripts/relais.py 27 %2$s", interval=0, autorun=true ]
Thing exec:command:valve5-control [ command="sudo /etc/openhab2/scripts/relais.py 17 %2$s", interval=0, autorun=true ]
Thing exec:command:valve6-control [ command="sudo /etc/openhab2/scripts/relais.py 18 %2$s", interval=0, autorun=true ]
Thing exec:command:valve7-control [ command="sudo /etc/openhab2/scripts/relais.py 2 %2$s", interval=0, autorun=true ]
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import RPi.GPIO as GPIO
import sys,os
import logging
logging.basicConfig(filename='/tmp/relais.log',level=logging.DEBUG)
logging.debug('launching Relais')
logging.debug(os.getegid())
logging.debug(os.geteuid())
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
#os.system("sudo echo "+str(sys.argv[0])+" > /home/openhabian/test")
logging.debug("Argv0:>>"+str(sys.argv[0])+"<<")
logging.debug("Argv1:>>"+str(sys.argv[1])+"<<")
logging.debug("Argv2:>>"+str(sys.argv[2])+"<<")
if len(sys.argv) > 2:
logging.debug("more than 2 arguments")
RELAIS_GPIO = int(sys.argv[1])# + int(sys.argv[2])
GPIO.setup(RELAIS_GPIO, GPIO.OUT)
#GPIO.output(RELAIS_GPIO, GPIO.LOW)
GPIO.output(RELAIS_GPIO, GPIO.HIGH)
if str(sys.argv[2]) == u"ON":
logging.debug("Turning Relais on")
elif str(sys.argv[2]) == u"OFF":
logging.debug("Turning Relais off")
GPIO.output(RELAIS_GPIO, GPIO.LOW) # an
else:
logging.debug("WRong number of arguments")
/tmp/relais.log
DEBUG:root:launching Relais
DEBUG:root:0
DEBUG:root:0
DEBUG:root:Argv0:>>/etc/openhab2/scripts/relais.py<<
DEBUG:root:Argv1:>>10<<
DEBUG:root:Argv2:>>ON<<
DEBUG:root:more than 2 arguments
DEBUG:root:Turning Relais on
