Hy,
My name is Mike and I started few days ago to learn openHab and to test things, now I want to control a relay with a reverse button, and i want to create a rule to check if state of relay is ON and then turn OFF and also if it’s OFF to turn ON,
I am new in codding and i don’t know what I’ve done wrong.
I need some help, please.
rule "buc1"
Item buc1_intrerupator changed
if (buc1_releu.state == ON){
sendCommand(OFF)
else if (buc1_releu.state == OFF){
sendCommand(ON)
Almost!! You are on the right track.
Well done so far, don’t give up
rule "buc1"
if (buc1_releu.state == ON) {
buc1_releu.sendCommand(OFF)
else if (buc1_releu.state == OFF) {
buc1_releu.sendCommand(ON)
Just because I can’t help myself, here’s a one liner.
rule "buc1"
buc1_releu.sendCommand(if(buc1_releu.state == OFF) ON else OFF)
I seem to remember that there was a TOGGLE command at some point. At least I remember it being an option with IFTTT integration. But I don’t know if there is any more or whether that was specific to the IFTTT openHAB channel.
i am back with a problem:)).
The if statement doesn’t work properly. if i push the button to close the light it remains closed until i take my hand from the button. like in the video attached
