inverter1ActivePower.state instanceof Number is boolean, true or false.
!(a) is 'NOT a'
So !(inverter1ActivePower.state instanceof Number) is true, if inverter1ActivePower.state is not an instance of Number (and Number is the type of data, like String, Boolean, Float or DateTime).
Here’s the problem you will face. I assume you are persisting these values to a database. If so then the negative number is going to be persisted as well as the 0 so at night the chart will be bounding between that large negative value and 0 until day time. So you need to convert the value before it gets to the Item, create a proxy Item, or take on the task of deciding when to persist in your Rule.
Rossko57 has a suggestion for converting the value before it gets to the Item. Create a JS transformation that returns the passed in value if it’s not negative and 0 if it is negative. This will convert the negative number to 0 before it gets to the Item, no Rule necessary.
For the Proxy Item the Rule would look something like:
rule "Process power"
Item inverter1ActivePower changed
if(!inverter1ActivePower.state isinstanceof Number) return;
var newVal = inverter1ActivePower.state
if((inverter1ActivePower.state as Number) < 0) newVal = 0
inverter1ActivePower_Proxy.postUpdate(newVal)
You need to put the Proxy on your sitemap and in your .persist file.
To take on the role of persisting the values instead of relying on the strategy the rule would look something like this.
if((inverter1ActivePower.state as Number) < 0) inverter1ActivePower.postUpdate(0) // this will retrigger the Rule
else inverter1ActivePower.persist("rrd4j") // Name your desired persistence engine
You must remove inverter1ActivePower from your .persist file or from any Groups that get persisted in that .persist file.
If the Item is NULL or UNDEF the Rule exits. You can’t run the rest of the Rule if the Item is in either of these two states.
A Rule runs after the Item get’s set to a given state (or receives a command). You can’t intercept the negative value from the binding and convert it to a 0 using a Rule. You can do so using a transformation.
To convert the value to 0 before it gets to the Item.
But it doesn’t run all the time. The rule runs when the Item changes, and then it might change it again to something else.
Your Item will be changing twice every polling period, all night long.
There’s no harm in that, but what is the purpose? Are you just trying to hide the silly value in a display?
If you are planning to produce charts from persisted data, have a think about what happens at each poll.
Exactly…
Rich is right, (as usual)…
I want to persist this item. But it´s stupid to persist a negative static number, when the inverter is in “standby mode”… (Its a rather borring chart I would say ).
Ofcouse… Sorry Rossko… I was so focused on changing the item value, that I simple missed the whole point, that this wont do any good… The transfomation wil have to go into the channel (binding) before it enters the item.
So I´ll have to change my question, cause I have no idea how to make this in a js transformation… I only know how to divide values but 10,100, 1000
The process is described in the binding docs, with examples
Take Rich’s little javascript an put it some file in /transforms folder.
Name it whatever - smalimit.js perhaps.
Now you just tell the data Thing to do a read transform, and what type it is, and what file to look at.
Thing data Active_Power [ readStart="30775", readValueType="int32", readTransform="JS(smalimit.js)" ]
I think the UNDEF scheme would work; however I don’t think the binding will ever supply a non-numeric value to the transform - it’s the nature of Modbus that all raw data is numbers. Does no harm having it there, though.
But it is possible to follow that thought some more…
Really, your “silly” value should show up as UNDEF - this is exactly what UNDEF is meant for, to represent that data can’t be calculated.
But if you are charting the data, you may prefer zero. UNDEF does not get persisted, and the last valid data may not have been zero, leading to a long time at a false reading in your chart.
Hmm you got a point… I honestly have no idea what the latest value is, ecept when the panels are NOT producing any power, then inverter will change state. So I assume it would be 0 (zero)…
So if I would use UNDEF insted of 0 (zero), I should change Rich´s script to:
2019-09-17 00:43:12.384 [ERROR] [nding.modbus.internal.Transformation] - transformation throws exception [transformation=JS(smalimit.js), response=-2147483648]
org.eclipse.smarthome.core.transform.TransformationException: An error occurred while executing script. ReferenceError: "UNDEF" is not defined in <eval> at line number 2
at org.openhab.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:80) ~[?:?]
at org.openhab.binding.modbus.internal.Transformation.transform(Transformation.java:144) ~[?:?]
at org.openhab.binding.modbus.internal.Transformation.transformState(Transformation.java:190) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.lambda$10(ModbusDataThingHandler.java:833) ~[?:?]
at java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1556) ~[?:?]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:647) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.processUpdatedValue(ModbusDataThingHandler.java:801) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.onRegisters(ModbusDataThingHandler.java:681) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.lambda$0(ModbusPollerThingHandlerImpl.java:95) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:891) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.onRegisters(ModbusPollerThingHandlerImpl.java:95) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusLibraryWrapper.invokeCallbackWithResponse(ModbusLibraryWrapper.java:286) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.lambda$1(ModbusManagerImpl.java:167) ~[?:?]
at org.openhab.io.transport.modbus.internal.SimpleStopWatch.timeRunnable(SimpleStopWatch.java:152) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:166) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:1) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.executeOperation(ModbusManagerImpl.java:575) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.lambda$15(ModbusManagerImpl.java:723) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: javax.script.ScriptException: ReferenceError: "UNDEF" is not defined in <eval> at line number 2
at jdk.nashorn.api.scripting.NashornScriptEngine.throwAsScriptException(NashornScriptEngine.java:470) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:426) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.access$300(NashornScriptEngine.java:73) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine$3.eval(NashornScriptEngine.java:514) ~[?:?]
at javax.script.CompiledScript.eval(CompiledScript.java:92) ~[?:?]
at org.openhab.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:77) ~[?:?]
... 24 more
Caused by: jdk.nashorn.internal.runtime.ECMAException: ReferenceError: "UNDEF" is not defined
at jdk.nashorn.internal.runtime.ECMAErrors.error(ECMAErrors.java:57) ~[?:?]
at jdk.nashorn.internal.runtime.ECMAErrors.referenceError(ECMAErrors.java:319) ~[?:?]
at jdk.nashorn.internal.runtime.ECMAErrors.referenceError(ECMAErrors.java:291) ~[?:?]
at jdk.nashorn.internal.objects.Global.__noSuchProperty__(Global.java:1442) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$12$13A$\^eval\_.L:1(<eval>:2) ~[?:?]
at jdk.nashorn.internal.scripts.Script$11$\^eval\_.:program(<eval>:1) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:637) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:494) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:393) ~[?:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:421) ~[?:?]
... 24 more
Probably. I very rarely touch JavaScript so usually the most primitive approach ends up in the code.If Nashorne supports Math.max then you can do that.
