I need help re-configuring these items to function on openHAB 2.
//ESP Dimmer 1 Switch
Switch ESP01Switch "Armtronix Light" <light> (All,Random_Switches) {mqtt=">[mosquitto:/esp/dimmer01/sub:command:on:R13_ON],>[mosquitto:/esp/dimmer01 /sub:command:off:R13_OFF]"}
//ESP Dimmer 1 Slider
Dimmer ESP01Dimmer "Armtronix Dimmer [%d %%]" <slider> (All,Quick_Access,Random_Dimmers,Morning,BedTime) {mqtt=">[mosquitto:/esp/dimmer01/sub:command:*:Dimmer\\:${command}]"}
Should I attempt this through a Paper White Thing? Or do I attempt binding with this configuration?
